Question about HP EliteBook Computers & Internet
Fan on when machine is off
When the machine is on the fan is off, when i turn the pc off the fan comes on and runs untill the battery is dead. i powered down machine removed battery let it sit over night. as soon as the battery made contact with board the fan turned on immediately. i tryed replacing the sys board and when i put the battery in to start the tattoo process (pc was still off) the fan kicked in again..??????any ideas would help.
    Sergeant:
  • 180 Answers
Dear/Aaron Ehlers
Make renovation bios ( by service tag ) And , of course, choose from standard mode BIOS "default" .
fan on when machine is off - 25673033-o3plf24a22mq4lc45ifko3ck-5-0.jpg Colors of black and red plug in any fan
good Luke
Posted on May 19, 2015
SOURCE: Toshiba Satellite A15-S129 PC Notebook will not turn on
I have the same problem. What I have found with mine is that if I can get the battery to take just a little charge then I can get it up and running. Here is how I do it. Disconnect AC power leave the battery in and start the laptop. As soon as thing start to run I plug the AC back in and it works fine from there on. Now mine is flashing as well now and I have a dead battery and it will not restart. Something I have noticed thought is it appears that the yellow light is blinking a code. This is what I have come up with. I appears to be flashing 323 as the code or could be 2 shorts 1 long then 2 shorts and then 3 shorts.
Anyone know where to find info on these flashing codes.
Thanks
Posted on Dec 14, 2007
  • 72 Answers
SOURCE: When power cable unplugs computer immediately shuts down (have replaced battery)
Sounds as if the power pin (inside the computer) is damaged. The part is under $ 10 but the labor is gonna be a hundred to two hundred bucks. You can, if you are careful, fix it yourself.
You can also get a JerkStopper cable retention device to hold the cable in the correct position until you get the pin fixed. The cable retention device is designed to keep you from damaging the pin by pulling on the power cord. In this case, it sounds like it's too late for that.
Posted on Jun 04, 2008
  • 38 Answers
SOURCE: Sony Vaio VGN-N250E/W Not Booting/Responding
Take the battery and power supply out and hold down the power button for 30 seconds. This will reset your hardware settings. Your backup battery isnt your problem. Does your battery light turn on when charging? Does your keyboard lights light up when it runs for a second (try pressing caps lock)?
Posted on Mar 25, 2009
Tech_Mania
  • 239 Answers
SOURCE: Laptop wont start up/POST
if even bios doesn't boot up...den its the motherboard problem..since its just few months old system it should b under warrenty...
Posted on May 25, 2009
ariyoso
  • 145 Answers
SOURCE: ibm thinkpad t41 does not boot up...just black screen...fan works
hehe...I used to have some problems
and then came up with the solution to install other OS such as linux, lindows or anything else
and then reinstal it with windows booting...and then it works, u can try it
Posted on Jun 21, 2009
I have a 2007 Toyota matrix and the fan that cools the motor will not shut off even when I turn the car off, this causes the battery to run down, any ideas what the problem might be
Does the fan really run until the battery goes dead?? OR are you afraid that it might run until the battery is dead?? In many cars, the fan will continue to run for a short time after you shut it off.... until the engine coolant is cooled to a certain point. It can also run for a while when you've been using your air conditioner. Now, if it is actually running continuously and won't turn off, there is a sending unit somewhere that isn't functioning correctly, either in your cooling system... or your air conditioning system. You're going to need to do some research and find out which sending unit might be the culprit..... or take it to the shop. They'll know what to do and can probably quickly fix it.
Dec 03, 2013 | Cars & Trucks
Trying to boot up my sons Compaq cq56-107sa circa 2010
The reason it worked is because there was an error within the memory and removing the battery removed the error.
Nov 02, 2017 | Compaq Presario Notebook
PC with ECS P4VMM2 V5.0A motherboard won't power up after working for years. Power supply fan doesn't come on, case fan doesn't come on, PC dead. Tried replacing power supply, same result. Power supply...
The mother board and the fan also need replacement. If you have recently added any other hard ware to the machine, remove it and try booting again.
Apr 11, 2011 | Computers & Internet
We have a Sony VAIO, VGC-LV290J. When plugged into an outlet, the machine's fan just revs. The "VAIO" splash screen does not appear and the screen remains blank. The Bluetooth keyboard does...
It seems that the 'POST' (Power On Self Test) is not starting, and thus is not displaying the "splash" screen. The fans will run at 100% until the POST completes.
But, if the POST does not complete, the fans will "roar".
Check for a defective CPU, or defective RAM, or a defective motherboard.
It probably is *NOT* the CMOS battery -- if that battery is dead, then the "default" settings should allow the computer to start (with the wrong date/time).
Mar 15, 2011 | Computers & Internet
I have a 2007 Trailboss 330 that has no more than 20 hrs of use. It has just sat unused scince being boughting in late 2006 and being riden just twice. Since then it was taken to the dealer for a fualty...
since it sat so long sensor or relay may be corroded or gummed up and giving a false reading [the fan is on battery circuit] so if u turned off machine and it was hot and temp rose to sensor setting fan would come on and start cooling and would go off when sensor reached lower temp also a battery sitting for 2 years in anything unless hooked to a trickle charger or a battery tender would be dead check wiring harness and sensor from oil cooler
Feb 15, 2010 | Polaris ATV
Hello, My HP Compaq 6720s is turned off and won?t start again, when I connect the charger it's turning on and of all the time until I disconnect the charger. When I try to turn on from the battery its jus...
When you say turning on and off all the time until I disconnect the charger, IS the charger running the machine and then after so long cutting out? you leave it and it works , if so its overheating
Machine will need fan and all ducts cleaning and most likely replace arctic silver on psu
IF on the other hand its not running more likely the charger is not powering the machine or charging battery in which case you will need new charger
hope this helps get back to me if you need more help
Jun 10, 2009 | HP Compaq 6720s Notebook
91 Legend cooling fan turns on by itself
Replace the cooling fan engine temp sensor switch, this may be the cause.
Nov 19, 2008 | 1991 Acura Legend
Computer turns on, but does not boot to XP
Generally, fans are controlled by heat readings...something to check is the operating temperature that is shown in your BIOS when you boot up...(access your BIOS by tapping on the delete key, or F2 key while booting)..if it goes over 70C real quick then there is a CPU heat dissipation problem, which would cause the fan to run like this i think that it is more of an issue that your CPU died...has your machine taken any kind of hit or fall that might have loosened things?...or perhaps the heat sink compound between the heatsink and CPU failed.....
but it also could be a dead MB
Jun 06, 2008 | Sony VAIO Digital Studio PCV-RX660 PC...
CPU fan operates but laptop otherwise dead ?
Remove the battery and plug in the power adapter. Attempt to power on the laptop. If nothing happens, then try holding the power cord, at the jack, at a different angle. Wiggle it a little and see if the laptop will come on. If it does come on, then wiggle it some more and see if the laptop cuts off.
This will determine if your DC Jack is faulty. I have resoldered a bunch of these on this model. Usually the solder around the HOT pin on the mainboard cracks. Thus, you don't get a good power connection.
Now, as far as the laptop coming on with the battery.... how long will it run on just the battery? A couple seconds? Or a couple minutes? Or until you turn it off? If the battery were about dead, then it would come on for just a couple seconds but not POST. Meaning no video or anything. But if it comes on and runs for several minutes without turning off, then a weak battery isn't the problem. It should still POST and show video and all that.
So, even if you get the DC Jack fixed, assuming its faulty, this may or may not solve your POST problem. Never know really until the dc jack is for sure supplying good steady power.
Oct 29, 2007 | Compaq Presario R3000 Notebook
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
