Question about John Deere Garden
John deere lawn tractor. Had a dead battery. my son tried to jump it but cables got hooked up backwards, cranked 10 sec. Now turns over but wont start and smokes under the flywheel
  • John Deere Master
  • 1,169 Answers
Because he shorted out the alternator under the flywheel. There also maybe other damage as these are not protected from reversed voltage.
Posted on Apr 30, 2015
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 69 Answers
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
John deere x540 with140 hours. Jump started from storage and cut 2 hours without issue. would not crank back up. Installed new battery and checked fuses. Lights and all come on but will not crank.
would not crank Chet, Relay,Solenoid or starter may be defective, give the starter a sharp bang with a hammer, to see if it is stuck.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Test lawn Mower Solenoids
How To Test Solenoid with Taryl
Electrical System Troubleshooting for Lawn Tractors Mowers
JOHN DEERE KAWASAKI RELAY
Mar 30, 2016 | John Deere Garden
I have a John Deere D130 riding mower that will not start. When I turn the key I get nothing. When I jump from the battery + to the solinoid the motor cranks. I have replaced the seat switch, the brake...
check out all the safety switches , they make a circuit on closed , = make sure your safe not in gear etc , put a shunt direct and make sure you have cuircuit
Jul 19, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
How to test a solenoid for a John Deere 115 Lawn Tractor with 42" deck?
http://www.greenpartstore.com/assets/images/instructions/2012/am138497_installation_instructions.pdf
John Deere Starter Solenoid Kit AM138497
First make sure the negative battery cable is making good contact on the frame or what ever part of the mower it is connected to. Make sure both battery cables are clean and not corroded and are tight. Then try to start the mower. If it works, fine. If not then you will bypass the solenoid and see if the starter turns the engine. To bypass the solenoid take a car jumper cable and connect one clamp to the terminal on the solenoid that goes to the battery ( see the diagrams in the links above) Turn the ignition switch to the on position. Take the other end of the same color of the jumper cable (say you'll use the red clamps) and touch the clamp to the other large terminal on the solenoid, which goes to the starter. If the starter turns the engine, then you know the starter is good and that the solenoid is bad. If the starter does not turn the engine then the starter is bad. make sure you DO NOT touch the jumper cable to the starter case or any other ground.
May 18, 2014 | John Deere Garden
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Brand new battery - Starter not engaging
Prbably an issue with the solinoid, try jumping between the two heavy duty cables on the solinod with a suitabke screw driver BE CARFULL, if the engine cranks replace the solinoid
May 17, 2013 | John Deere Garden
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
My john deere 425 wont start cranks motor spins will run a few sec with starting fluid then dies
Check your fuel filter and see if it's clogged. You might be able to blow it out with an air hose if it is.
Feb 08, 2011 | John Deere 132 425 Lawn Tractorsnow...
John deere 316 won't start
not sure but i think check the battery i am fighting the same problem and i jumped it from my truck and it runs fine i am looking for a battery tto dya
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
111 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
