Question about Bosch Kitchen Ranges
After a power outage my cook top & oven will not heat, how do I reset?
  • Bosch Master
  • 5,631 Answers
Did you check BREAKERS
Posted on Apr 30, 2015
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
Error message
try resetting the 40 amp double breaker in the panel
Nov 19, 2013 | Kenmore Frigidaire Glass Cook Top...
HOW TO LIGHT OVEN WITH A MATCH
Look up product manual on internet.
Look at label located inside oven door, and add .pdf to search parameter to help find manual.
Then read section about lighting appliance.
If power is out, then pilot will not have any gas >> if gas control is electronic.
Many electronic gas controls require electric power to operate circuit board.
In old days, you removed the bottom tray on oven to access burner and pilot orifice. Then you pushed down switch to release gas through pilot tube, and put lit match into the gas stream to light pilot. Hold down switch until pilot flame heated tip of thermocouple which caused magnetic switch to stay open inside gas control. Release switch and pilot stayed lit.
Safety concerns and vast advances in manufacturing cheapness have changed gas appliances so they are more inconvenient for do-it-yourselfers during ordinary power outage.
Cook hamburger over metal bucket with newspaper, and grease on newspaper burns enough to cook hamburger.
People always buy generators and flashlights, but nobody suggest buying barbeque briquets and starter fluid as way to keep warm and cook.
Oct 29, 2012 | General Electric GE 24-Hour Power Strip...
Whirlpool oven won't heat after power outage
you will have to press the hand on your timer it needs to be set back on manual its on time cook you will hear it click back and your oven light will come on and heat read how to in the book that came with your oven
Nov 06, 2011 | Ovens
Had a storm the range works but the oven went out model number 8114P732-60 Maytag advance cooking system super cap. is there a reset button
There isn't a reset per say but you can turn the unit off at the breaker box for the home for 1 to three minutes. If this does not work...either the heating elements were blown during the power outage or the control board is now fried from the surge and needs replaced.
Sep 01, 2011 | Maytag MER5775Q Electric Kitchen Range
All the lights, display, etc. work on the oven but no heat
First and foremost check the breaker box. Ovens use 240 volts which is a double breaker in the box. Just to be safe I would click both breakers off and then back on together. If this doesnt work turn off the power and have someone help you pull the oven out and check your plug or connection. You may be dealing with a broken wire in the junction box due to the power outage. If you have a volt meter turn the power on SAFETLY and test if your getting 240 volts. If the connections are good (including the one from the juction box to the stove itself) and you are getting proper votage, unfortunatley you are going to have to get a new control. What happens is with only 120 volts going to the oven everything runs but your elements (they utilize the 240 volts to heat). You can tell time or use the timer but without your full 240 your turkey aint gonna cook. There is 120 volts coming coming from each of those breakers you checked in the garage. Bottom line is the chances of both elements going out at the same time are slim to none and I feel you are probably dealing with a broken wire.
Jan 23, 2010 | Whirlpool RBS305PD Electric Single Oven
We has power cut put power back on switched oven on it wont get warm
Make sure the oen has not gone into Auto cook mode. This sometimes happens after a power outage.
Try resetting the clock and if the is an Auto/Manual button press this also sometimes this does the trick.
Jan 01, 2010 | Neff Ovens
Krups FBC2 Convection Toaster Oven Simply no power at all.
Having a toaster oven and a coffee maker on the same circuit is asking the breaker to trip in the house electrical panel, but I guess that you have learned the drill: only one appliance on at a time. Try moving the oven to the working side of the socket (the two socket sections can be spit apart and power each half from a separate house breaker and wiring). If the oven now works, check for a tripped breaker in the house panel. If the oven still doesn't work, look for a reset button near the cord entry point. Many heating type appliances have a thermal fuse that opens when things get too hot, but you need to get inside the cover where the cord enters.
Oct 11, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
MY MICROWAVE OVEN CUTS OFF AFTER JUST A FEW SECONDS OF COOKING
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 17, 2009 | GE JVM1630 Microwave Oven
Kitchen Ranges Logo
80 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
