Question about Kenmore Kitchen Ranges
Why do I get fumes from my oven some - Kenmore Kitchen Ranges
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 644 Answers
You might have a weak ignitor.
Or, If you just recently acquired a used range, it's possible that it may be set for natural gas and you've got propane gas; or vise-versa.
Posted on May 27, 2015
Strong fumes from new frigidaire gas oven.what should i look for
If it smells like gas Shut the gas off outside call installer, or
gas company. If it doesn't smell like gas, most likely it's the "new smell" caused by the heat. If you have a kitchen vent fan turn it on. If it persists Call the installer or dealer. No action by them? call the mfg customer service number in your owner's manual. It's possible something was left in the oven burner area that shouldn't be there.
Feb 27, 2015 | Frigidaire Kitchen Ranges
Why does my fan oven smell of fumes when switched on
could be a couple of reasons. if it is a new oven, it will smell for the first few times, they all do. If you have cleaned the oven recently it could be the residue burning off.
Oct 17, 2014 | Microwave Ovens
Necht gas oven
May need to adjust air Venturi too much air
Mar 27, 2014 | Ovens
Removed aluminium foil stuck to oven with pool acid - is it safe to use now?
kill the acid with some caustic soda - normal oven cleaner
then you can cook free of acid fumes
Jan 01, 2014 | Ovens
My husband sprayed the non-fume Easy-Off oven spray into our KitchenAid self-cleaning oven. Then turned IT ON TO CLEAN! It was on for about 1/2 hour. There are instructions all over the can NOT to turn...
The best thing to do is with a cold oven, go ahead and use the Easy-Off non fume again and wait 2 hours. This should remove the original grease as well as the left over Easy Off from the 1st application.
Jun 05, 2011 | Ovens
The oven leaks gas fumes into the house and will "blow up" if not opened every 30 minutes. it forgotten and left on for an hour, it may blow out from under. This oven was converted from natural...
incorrect conversion- valves to large - gas should not leak at all- should only FLOW when in use- TURN OFF GAS TO STOVE- EXTREME FIRE HAZARD
May 10, 2011 | Jade Ovens
Smoke and fumes coming from oven
Sounds like you need to clean the whole oven as old grease and spillages will keep on burning and smoking.
Jan 03, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
NEFF OVEN PROBLEM - SMOKE AND FUMES COMING OUT OF OVEN
Take the cover off that is surrounding the fan and you will probably find food or something there or on the fan blades. If it is not a food smell, then there is probably some wiring that is burning. I suspect that there is food behind the housing of the fan.
Feb 02, 2009 | Ovens
I NEED TO KNOW IF IT IS SAFE TO RUN MY SELF CLEANING OVEN WITH MYSELF AND PETS IN THE HOUSE. THANK YOU IN ADVANCE IF YOU CAN ANSWER THIS QUESTION.
The general answer is yes, however if there is a lot of build up in the oven the self clean cycle may result in irritating smokey fumes. It's always best to clean the oven before there is a heavy build up, and at a time when you can open a window or two if the fumes start to bother you. If there is a build up on the floor of your oven now, you can try using a plastic spatula to scrape off some of the real heavy stuff before self cleaning. This should be a FixYa for you and your cats. Thanks.
Dec 07, 2008 | Kitchen Ranges
Oven fumes
HI ,
Align the burner to gas nozzle at the back side cover , if still ajusment make it closer nozzle to burner so that gas will not spell out,
Dec 19, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
70 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
