Question about Acer Aspire 3000 Notebook
Aspire 3000,suddenly contrast is all wrong to bright
It's not the setting
I checked.
Suddenly the contrast of the laptop went all bright
I tried to tone it down , but it only helped a little bit
The colors or all wrong
Can somebody please help.
And another thing , the plastic at the hinges or breaking off
  • 175 Answers
The picture on my Samsung LN46A630M1TXZA LCD TV suddenly went haywire while watching. The pictures of people look cartoonish/posterized. I tried adjusting the contrast and brightness but I still hav
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 16, 2015 | Samsung Televison & Video
How can i turn down contrast on my laptop
Acer Aspire one
Brightness is controlled by the Fn and arrow keys.
Contrast can be controlled from the software.
FN key, + left/right arrow key's
other Acers
Log on to your Acer laptop and click on the "Start" button. Choose "Control Panel" from the menu.
Double-click on the "Display" icon in "Control Panel" and select the "Settings" tab.
Check the "Color Quality" settings and make sure they are set to either medium or high.
The high setting will give you better color quality and contrast, but it will also use more system resources and shorten battery life.
If you are operating on battery power you may want to move the setting to medium.
Hold down the "Fn" key and press the right arrow at the same time.
This key combination will increase the brightness of your screen.
To decrease the brightness and contrast, hold the "Fn" key down and press the left arrow. Continue using these key combinations until you have found the optimal setting for your laptop display.
hope this helps
Oct 08, 2012 | Acer Aspire One D255E13438 Netbook
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
Why does my acer aspire 3000 keep turning suddenly off if i play online games on facebook?
Can be many factors, Need to buy new memory. If the fan turn it off the processor can be burned. I suggest take the notebook to a repai shop to check it
Oct 29, 2010 | Acer Aspire 3000 Notebook
Screen very dim do i turn up the contrast /brightness
Hello !
Test with an external monitor. If it works, there is a problem with the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
May 08, 2010 | Computers & Internet
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
Brightness and contrast increases suddenly
Check following:
1- VGA chord; is it loose or faulty?
2- Power Supply section not regulating perfectly.
3- Supply line from SMPS/Regulator power supply to EHT.
4- Brightness lines and controls (Resitance may be dry soldered or burnt)
5-Pin connection on rounded board of CRT neck may be loosed, Check it if loose than fit properly.
6- Adjust the precet for accelearting and focusing anode externaly fixed with EHT if inbuilt in EHT than only solution is to replace the EHT only.
Feb 15, 2010 | LG Computers & Internet
Faded out Acer LCD screen
It's not a contrast / brightness issue, even at the lowest setting the screen would look normal and probably not the way you're seeing it now. It's likely that the inverter or backlight went out on the lcd. You could possibly turn them up the highest level, but it would still need to be serviced by Acer for it to work correctly.
Glad to hear you've got the extended warranty.
Best of Luck!
Feb 23, 2009 | Acer Aspire 1800 Notebook
To increase the brigthness and contrast
i have a gateway laptop and i would like to increase the brightness
Jan 12, 2009 | IBM ThinkPad T30 2366 Notebook
Monitor dark PRoview PL916s
try to contact an expert technician of monitor maybe there is a part of your monitor that is already defective, the controller of brightness and contrast.
Jan 14, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
