Question about Kenmore Kitchen Ranges
Why do I occasionly get fumes from my oven - Kenmore Kitchen Ranges
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 646 Answers
You probably have a weak ignitor that is not lighting the gas quickly or reliably.
Posted on May 27, 2015
Why does my fan oven smell of fumes when switched on
could be a couple of reasons. if it is a new oven, it will smell for the first few times, they all do. If you have cleaned the oven recently it could be the residue burning off.
Oct 17, 2014 | Microwave Ovens
Removed aluminium foil stuck to oven with pool acid - is it safe to use now?
kill the acid with some caustic soda - normal oven cleaner
then you can cook free of acid fumes
Jan 01, 2014 | Ovens
My husband sprayed the non-fume Easy-Off oven spray into our KitchenAid self-cleaning oven. Then turned IT ON TO CLEAN! It was on for about 1/2 hour. There are instructions all over the can NOT to turn...
The best thing to do is with a cold oven, go ahead and use the Easy-Off non fume again and wait 2 hours. This should remove the original grease as well as the left over Easy Off from the 1st application.
Jun 05, 2011 | Ovens
The oven leaks gas fumes into the house and will "blow up" if not opened every 30 minutes. it forgotten and left on for an hour, it may blow out from under. This oven was converted from natural...
incorrect conversion- valves to large - gas should not leak at all- should only FLOW when in use- TURN OFF GAS TO STOVE- EXTREME FIRE HAZARD
May 10, 2011 | Jade Ovens
We too ended up with melted reynolds wrap standard aluminum foil lined and then melted to the bottom of our oven. The smell was terrible. The thing was, we didn't know it was the aluminum foil until we had...
It is very difficult to melt Teflon; 326.8 degrees Celsius or 623.24 degrees Fahrenheit, hotter than most ovens! Rapeseed cooking oil will have long before caught fire.
Teflon is not used on oven floors, walls or racks.
The melting temperature of aluminium foil is 660 degrees Celsius (1,220 degrees Fahrenheit) at standard pressure, so it won't melt with temperatures encountered in a standard household oven!
Toxic fumes from the Teflon chemical released from pots and pans at high temperatures may kill pet birds and cause people to develop flu-like symptoms (called "Teflon Flu" or, as scientists describe it, "Polymer fume fever").
Oct 15, 2017 | Ovens
Smoke and fumes coming from oven
Sounds like you need to clean the whole oven as old grease and spillages will keep on burning and smoking.
Jan 03, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
NEFF OVEN PROBLEM - SMOKE AND FUMES COMING OUT OF OVEN
Take the cover off that is surrounding the fan and you will probably find food or something there or on the fan blades. If it is not a food smell, then there is probably some wiring that is burning. I suspect that there is food behind the housing of the fan.
Feb 02, 2009 | Ovens
Oven fumes
HI ,
Align the burner to gas nozzle at the back side cover , if still ajusment make it closer nozzle to burner so that gas will not spell out,
Dec 19, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
70 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
