SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
SOURCE: Set will not power on.. Blinks red LED 8 times
It's a power supply related problem.
The flashing 8 times is a trouble code. A Service Manual for your TV model will have the info on the codes. It could be a bad capacitor or a transformer on the power supply board.If you have some electronic experience, you can find a Service Manual for your TV over the internet. Cost about under $20.
SOURCE: red light blinking
You have a bad main board most likely. You can try unpluging it for 5 minutes.
SOURCE: tv won't turn on, only blinks a red led infront
could have bad caps in the power supply.They will swell up when bad,heat damage.These caps should be replaced with high temp caps.Capacitors go bad in monitors because cabinets are made thincausing less ventilation,more heat.bad caps will have round instead of flat tops
SOURCE: Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
