Question about Broan-NuTone Allure II QS230SS Kitchen Hood
How do I remove the filters from a Nutone allure kitchen exhaust fan?
5 Suggested Answers
SOURCE: Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Posted on May 14, 2008
SOURCE: Changing fuse on Nutone Allure Ws2
Hi Mertl, I sure hope you found the solution since, but I am posting the answer for other people like me (and you) who need to find it !
The service manual says:
To replace the fuse:
1. Disconnect power at service entrance.
2. Remove filters, bottom panel, light wire harness, and air chute.
The fuse is actually right behind the fan controls, so to access it you need to disassemble everything that's in the way.
BTW, for anyone wondering if it's the fuse that's faulty, here's a clue:
If the fuse has opened (blown), the green fan-level indicators
will operate properly when the fan buttons/switches are pressed
- but the fan and lights will not turn on.
The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
Good luck all !
Posted on Oct 05, 2008
SOURCE: Nutone Allure fan has disco lights.
Its definetly the control board!!!
Part #R111632
Price $110.00
Definetly not cheap...
Posted on Feb 08, 2009
saailer
  • 1871 Answers
SOURCE: HI My Nutone Allure is a
Hello! The baffle that directs exhaust through the outside vent is incorrectly installed...A common problem...Installation step #9 states; "Rotate baffle then re-insert into air chute so that tabs fit all the way into slots in air chute...An audible "click" will be heard when fully installed...Guru....Saailer
Posted on Sep 18, 2010
How to remove grease from fan 'blades' withut removing motor
the fan should come right off. they screw on,- or they have a set screw,- or they have a clip,- or sometimes if they are plastic they just pull off. this is all assuming that you can get to the fan.
Oct 09, 2010 | Broan-NuTone Allure QS130SS Kitchen Hood
When i removed the burnt out bulb, the whole socket, (rings) came out with the bulb, I didn't notice it until I returned with new bulb, at that time old bulb was already gone.... can i purchase a new...
I am sure that part is still available, however a model number would help in locating the part. NuTone has three different Allure series. You can check here for the part this is NuTone's website
http://www.nutone.com/index.asp
Or this company has a form to help you find the part
http://www.centralvacuumstores.com/fan_help.php
Aug 29, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Part #R111632
Price $110.00
Dec 22, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Good luck all !
Aug 16, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Broan allure performance ring
Are you looking for the metal ring which goes around your blower wheel. If so, we do have it at Inventex. All it does is cut down the performance of the fan. You will also need carbon filters to absord the smell.
Call us at 1-800-363-0566 Inventex
May 14, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Filter light on Problem
ControlBoard. Part # R111638. I do service calls for broan & Nutone
Jean-Marc
Jan 06, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Oct 30, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
220 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
