Question about Xerox WorkCentre Pro 90 Copier
What does the fault code 09.210.00 mean? - Xerox WorkCentre Pro 90 Copier
Forgot to give my car details in my question about the meaning of fault code P2243. its a 2005 skoda octavia 1.6 petrol
Fault code P2243 means that oxygen sensor seems to be faulty. This is generic OBDII-fault code. If possible vag-com or compatible fault reader could give more detailed information and also live-data from the sensor.
https://www.engine-codes.com/p2243.html
Sep 06, 2017 | Skoda Cars & Trucks
Hi my dishwasher is showing h4/5/6, wht does this mean please?
Check this link here
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3714-beko-electronic-dishwasher-fault-codes
H4/5/6 pretty sure it means errors H4, H5, and H6 hope this helps
May 03, 2016 | Dishwashers
Help!!!cant find what fault code means
P4040 code that is a non specific code that could be either EGR control circuit malfunction or security shut down mode meaning that the security system is shutting off the spark and/or fuel.
Sep 20, 2014 | 2001 Daewoo Lanos
What does code po700 mean on a cadillac cts 2006
P0700 is an informational code only. It doesn't point to a direct fault in the engine, only a general fault in the transmission. More diagnosis is necessary to identify what the transmission fault is. This requires a scan tool that will communicate with the transmission module.
More often then not, the cause of this code is that there is a transmission problem of some kind. The TCM detected the problem and set a code. P0700 means that a fault code is stored in the TCM. However this doesn't rule out the possibility of a failed PCM or TCM (unlikely).
For a P0700 the only real solution is to acquire a scan tool that will communicate with the transmission control module. Extracting this code from the TCM will be the first step in repairing the fault in the transmission.
Apr 02, 2014 | 2006 Cadillac CTS
What do the codes P1684 and P0700 mean?
Hi Rich Stuck,P0700 means Transmission Control System (MIL Request),P1684 means Battery Disconnected within last 50 starts.More read Diagnostic Trouble Code Table ,hope it can help you.
Dec 08, 2012 | 2002 Chrysler PT Cruiser
What does the service code p1111 mean?
Copied directly from a Jaguar forum:
P1111 is not a fault code. It is a special designator Jaguar uses meaning system ready, drive cycles completed after the last fault event. P1000, on the other hand, means system not ready, or drive cycles not completed after the last recorded fault event.
Some OBD II Basics - All P0xxx codes are generic and uniform across all manufacturers and mean the same on every car. All P1xxx codes are manufacturer specific codes. You cannot use a generic code chart to analyze P1xxx codes for a Jaguar.
Next time your car displays an engine fault light, try reading the codes then. If you have a CEL illuminated and the only code read is P1000 or P1111, then you probably have a fault that generic code readers cannot see. Could be a chassis code, for example.
One last thing - Neither P1000, nor P1111 can be erased.
Hope this helps you.
May 20, 2011 | Jaguar X-Type Cars & Trucks
2007 Volvo XC90 fault codes-ECM P030000, P030100, P030300, P0304000, what do they mean?
first code means random/multiple misfire cylinder (s) detected
second code means misfire detected number 1 cylinder, third code, miss=fire number 3 cylinder fourth code misfire number 4 cylinder
causes can be spark plugs, HT leads, ignition coils, injector, wiring fault, low compression/ engine mechanical fault
Jun 04, 2010 | 2007 Volvo XC90 V8 AWD Sport
My ST 92 Salva Oven displays fault code AL 3 what does it mean
my salva st-92 oven is displaying AL9 fault code
May 05, 2010 | Ovens
What does fault code P0001 mean 95 xj6 jag
What does the code Pro 1 mean on a 1995 jaguar XJ6
Apr 24, 2010 | 1995 Jaguar XJ6
41 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
