Question about Canon Office Equipment & Supplies
How to print DL envelope on canon irc4080 - Canon Office Equipment & Supplies
  • 3 Answers
SOURCE: Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Posted on Jan 09, 2008
  • 214 Answers
SOURCE: printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Posted on Jun 19, 2008
VOTIT
  • 2071 Answers
SOURCE: Just got a Canon PIXMA
On a PC...
- Ctrl + p to print
- Choose the Canon MP520 if it's not already selected
- Click Properties button
- Page Setup tab
- Select Printing
Posted on Jul 25, 2008
keithd2704
  • 56 Answers
SOURCE: Envelope feed problems
The problem is due to the type of envelope materials you are attempting to print on. The envelope stock (paper) is much too thin or lightweight. This is the primary cause of the wrinkling.
I would suggest that you switch to a heavier envelope material, but try to stay away from linen envelopes, as these will tend to wear down the fuser mechanism faster that normal. Most printers and copiers all have this classic problem.
I worked as a design engineer for Kyocera-Mita America for nearly 6 years and have seen this problem many times over and the only available solution is to change the stock. I (KMA) did work with a company in Canada who developed a specialized mass envelope feeder system for many of our systems. However they made major design changes to the feed mechanisms and feed roller pressure to deal with lighter stock materials.
Hope this information helps you out.
Cheers,
Keith
Posted on Oct 23, 2008
SOURCE: Print 6 3/4'' envelopes on a Canon d320
Press additional functions button, then use the + button to go to paper setting and use the + button to get to paper size, then using the + or - button to get to envelope and then if you push the + or - button you will get different sizes i suppose they are, but not sure what exactly they mean. I don't have any small envelopes to test it with your specific size, but finally just realized on to print #10 envelopes on it.
Posted on Jul 21, 2009
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
I have a Canon MP460 & cannot print DL envelopes from a .pdf as there is a grey band showing in preview:composite. Nothing prints in this band. How do I remove it?
This appears to be a bug with the Canon software. It is not using the correct dimensions for a DL envelope.
The solution is to use a Custom Paper Size. Make it 110mm wide and 220mm high (which are the correct dimensions for a DL envelope).
To make it easy to select this size in the future, set the Custom Paper Size (plus any other options you want) and then click on the Save button. When the save dialog appears, click on Options and make sure that "Save the paper size setting" is checked. Then enter a suitable name (e.g., "Envelope DL Custom") and click OK.
Nov 04, 2010 | Canon PIXMA MX310 All-In-One Printer
How to print envelopes using a Canon i560 printer?
Support site http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9282
if you click on the support and service TAB - and then look for "frequently asked questions" on that page Item 7 7. How do I load envelopes?
Also includes details of how to set the print driver up
Printer Driver Settings
  • Media Type : Envelope
  • Page Size: Select either DL Env. or #10 Env. according to the envelope size you are using
  • Orientation: Landscape
Apr 10, 2010 | Canon Office Equipment & Supplies
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot print envelope on MX310
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
    Note:
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
old marine
old marine
