Question about Bose Built-invisible Ta-1 Theater Amplifier
Can I use a turntable with this system?
My thoughts are that I should be able to plug my turntable into a preamp then plug the preamp into the AUX. of the Multiroom Interface box.
  • Bose Master
  • 5,259 Answers
If the Aux is Audio in then I don't see why not. The turntable would have to go via a magnetic cartridge pre-amp though. Or the sound would be too low to really hear.
Posted on May 04, 2015
How to connect a technics turntable using a phono preamp
plug the RCA phono plugs from tuntable into preamp in & then plug the preamp out to an open RCA plug on your amp or receiver like tape 1 or CD or aux.
Feb 07, 2014 | Audio Players & Recorders
The sound is really low if i press the aux tape cd phono or vcr the sound is there but really low
Instructions:
Evaluate your current receiver. Take a look at the back-panel connections to make sure you don't have a phono input. In most cases, the phono input will be clearly marked. If the connections are not marked, look for a set of RCA-style inputs with a grounding screw next to them; this is a phono input. If there isn't a phono input on your receiver, see if you have an open set of RCA inputs. If they are all occupied by other equipment, you can disconnect one piece of equipment, buy an A/V switcher or get a new receiver--preferably one with a phono input.
2 Purchase a phono preamp. The voltage output of a turntable is much lower than those of other peripheral devices, including CD players, tape decks and game systems. Although the inputs look the same, connecting a turntable to a standard RCA audio input will result in very faint sound output, if you hear anything at all. The output of your turntable must be amplified to a level of about 150 millivolts (mVs) before it reaches the receiver, so a turntable "pre-amplifier" or phono preamp is necessary.
3. Purchase patch cables. You'll need a set to run from the preamp to your receiver. Measure how long your cables need to be, and purchase accordingly. Resist the temptation to "go cheap," because better-quality cables will provide better sound.
4. Connect the preamp into the system. First plug the preamp into an AC power outlet. Most models have a small AC-to-DC adapter built into the plug. Then connect the cables from the turntable to the preamp, and connect your new patch cables from the preamp to the receiver.
5. Adjust the gain of the phono preamp. Most models have a gain control for fine-tuning. Follow the instructions provided by the manufacturer and adjust your system accordingly.
F150 Parts.
May 27, 2012 | Audio Players & Recorders
How do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
Apr 15, 2012 | Marantz Audio Players & Recorders
Hi I have a Technics SCEH790 CD Shelf System, plus a pre amp phono stage for my turntable, I have had this working in the past as it was a friend who whirerd it all together, I have moved my hi fi to a...
PHONO PREamp. Does that suggest anything?
No picture necessary. YOU can see it. I can visualize.
Turntable to the Pre-amp IN. Preamp OUT to ANY available RCA input (usually AUX,).
Mar 22, 2011 | Technics SCEH790 CD Shelf System
How do I connect a technics turntable to an RX-V463 AV reciever? Thank you in advance
Modern AV receivers rarely contain PHONO preamps.
A traditional turntable requires a preamp inline with it to PRE amplify and frequency-balance the minute signal produced by it's cartridge. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Yours does NOT.
A standard turntable will require you to acquire an external PHONO preamp to place between the TT and an Aux connction on the receiver.
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment. If your turntable is that type you can select its internal preamp output and run that to an AUX input.
Jan 15, 2011 | Audio Players & Recorders
How do I connect my turntable to my micro hi fi.The only sockets I have on the hi fi are aux and headphone socket.
You will need to look for a magnetic cartridge preamp this will then plug into the aux socket. If you need that socket for something else I suggest you get a switcher box. You might even get one with a cartridge pre-amp built in!
Jul 31, 2010 | ION Audio iTTUSB Turntable
Adding turntable to bose music wave system
Hiya, sad to say it wont work even with the correct plugs. If you really need/want to get it going, you will need a RIIA pre amp to use to convert the turntable levels to an acceptable level for the bose. Once you have that, then get the correct matching plugs for the bose (sames guys that supply the preamp should be able to help). Suggest a google search in your area "RIIA PREAMP" and see who supplys.
Best of luck
Jul 15, 2009 | Bose Wave Music System CD Shelf System
PL-88FS with modern HDMI Receiver
Hi...
If the new receiver doesnt have a specific input in back labeled "phono" , You WILL need a preamp for the phono. Then plug the preamp into the AUX or other available input
Jan 18, 2009 | Pioneer PL-990 Turntable
No Volume For My Music Hall MMF-5 Turtable
You will need to obtain a phono preamp to connect between the deck and the amplifier. I do not think this turntable is fitted with its own preamp - check the User Guide.
Jan 12, 2009 | Music Hall MMF-5 Turntable
Volume
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Aug 24, 2008 | Technics SL-1200MK2 Turntable
Bose Built-invisible Ta-1 Theater Amplifier Logo
198 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
