Question about Refrigerators
Where are the coils on this fridge? - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 52,099 Answers
Google make and model you MIGHT find it there .
Posted on Apr 30, 2015
How much is it to replace coil in maytag side by side fridge
Depending on the age of your unit, having to skin the unit to get the coil out, remove the bad coil, weld the new coil in, pressure check it, pull a vacuum for 4 hours, then charge it could cost upwards of $2500. More depending on the fridge. When your replacing coils, it's time to go buy a new fridge. It's not cost effective and the waranty would only cover the coil
Jan 22, 2018 | Maytag Refrigerators
Tip
FRIDGE NOT COOLING THAT GOOD
AT THE BOTTOM FRONT OF THE FRIDGE, UNDER DOOR, REMOVE VENT COVER. JUST SNAPS IN PLACE. USE A SHOP VAC OR VACCUUM CLEANER WITH A SMAL ENOUGH HOSE TO INSERT THROUGH THE BOTTOM OF FRIDGE. CLEAN COIL AS GOOD AS POSSIBLE FROM ALL DUST AND DEBRIS. DO NOT USE ANYTHING POINTED OR SHARP BECAUSE COIL CAN BE PUNCTURED OR DAMAGED. ONCE COIL IS CLEANED YOUR FRIDGE WILL START GETTING COLD AGAIN!!!!
on Jan 09, 2010 | Refrigerators
Tip
Fridge running constantly ,and not cooling effectively?
you need to remove kick plate from bottom of fridge and blow out the condensor coils .some fridges have coils in the back.so you will need to remove back panel at bottom of fridge .if coils are plugged,heat can not be removed from freon.it will begin to super heat before it reaches capilary tube.
on Dec 06, 2009 | Refrigerators
Sounds like it's working but not getting cold enough in freezer or refrigderator
In my experience, the biggest culprit causing these symptoms is the defrost heater. This is a heating device that melts frost off the "evaporator coils" better known as the coils usually located inside the freezer area of the unit. These coils get very cold and warm air that is let inside when any door is open, will carry moisture with it that will accumulate like water on the outside of a cold glass in summer time, only it accumulates on the evaporator coils and turns to frost.
As your fridge cycles through its operating stages, one part of the cycle turns off the cooling and turns on a heating device of varying types to melt the frost and ice off of the evaporator coils so it can drip down and flow through a small hose through an opening in the bottom of the fridge and into a pan underneath the fridge where it evaporates back into the air again.
If the heating device never comes on, or becomes inoperative, the frost will slowly continue to collect on the evaporator coils until it becomes a solid block of ice. This now greatly reduces the ability of the evaporator fan to blow the cold air around the coils throughout the freezer and the rest of the fridge. The ice built up around the evaporator coils will still provide some cold, but will significantly prevent the fridge from operating properly.
Another cause may be the evaporator fan not operating correctly. If it doesn't blow air over the evaporator coils well enough, cold air will not get distributed through out the fridge. Cold air tends to "fall", so the bottom of the freezer will be the coldest. Generally, there is an adjustable hole in "side by side" units so that the amount of air coming through that hole can make the "meat crisper" colder. In fridges where the freezer is on the top, I've seen the evaporator coils (which often incorporate "fins" like those on a car radiator, turn into a solid block of ice.
25823064-nzcmabjorfygbev20le00e4d-4-1.jpg Also check for dust collecting on the condenser coils on the outside of the fridge. These dissipate heat drawn from inside the fridge and take it outside the fridge. These are often located on the back of the fridge or underneath the fridge. Dust and fluff act as insulation and degrade their ability to work properly.
Obviously, to repair the fridge, you should relocate the contents of your unit until you can repair the fridge. Fixing your fridge will take at least a few hours even if you can get your hands on repair parts quickly. This will involve unplugging the unit and locating the items I've referred to. Either allow the accumulated ice to melt naturally or GENTLY speed up the process with a hair dryer or heat gun. Do not use any force removing the accumulated ice and frost, you could easily damage the coils and make things much worse than they already are. Even to the point of making the unit uneconomical to repair.
Without your posting a make, model, type of freezer/fridge arrangement or other details, it is difficult to assist you further. Part placement and component locations vary greatly in this appliance.
Aug 15, 2015 | Refrigerators
Samsung fridge coils frozen over on refrigerator side.
Not sure what the ohms should be,but ckeck coils for damage you may have a leak
Dec 07, 2013 | Refrigerators
How any fridge keep things cool inside it
are you asking the basics of refrigeration? if so here it is. refrigeration is the absence of heat. air inside the fridge is blown across cold coils. the freon inside those coils pick up or remove the heat from the air. the freon then takes this heat to the coils that are on the back of the fridge or under the fridge to get rid of it so it can pick up more heat inside he fridge and the process starts all over again. This is why it is so important to keep the outside coils clean. the outside coils have to get rid of the heat.
freon can not pick up heat inside the fridge if it can not get rid of the heat outside of the fridge.
Your homes air conditioning works the same way and so does any window air conditioners.
hope this is what you were asking for.
Jun 11, 2011 | Refrigerators
You say clean outside coils and fan motor coils. Where are they?
The "outside" coils that you are looking for on a refrigerator will be found either on the back, or in the case of your Amana, on the bottom - behind the toe space bezel. There are no coils on the back of the fridge.
The coils are usually thin, black grates that contain the refrigerant. Be careful not to damage them when cleaning. Open the freezer door (yours is a bottom freezer type) and simply grasp at the top of the bezel an gently pull away from the frame.
Use a narrow crevice vacuum tool attachment to pull the dust and debris from the coils. Use a flashlight to see beyond the very front. You may also wish to unplug the fridge so that you do not damage the fan if it is struck by the tool while running. You should vac the coils annually or more frequently if the fridge is in a dusty area - or there is a lot of pet hair collecting on the coils. Some fridges also have the fan hidden behind a removable panel on the at the bottom of the back side of the fridge. If cleaning fan blades - you must unplug the fridge before attempting. Vacuum any dirt and dust on visible coils seen near the fan.
Mar 29, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer is ok, but fridge is not cold enough
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked.
Sep 01, 2009 | Kenmore Refrigerators
My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 26, 2009 | Daewoo Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
