Question about Freezers
Why is my 2-month old fridge/freezer beeping intermittently?
3 Suggested Answers
  • 44 Answers
SOURCE: Fridge/Freezer cools intermittently
It could be the thermostat. When you catch it in a cycle where it's warming up, gently tap the dial with the handle of a screw driver. If it starts chances are it's bad. If you know electricty you can jump the two terminals on the thermostat to do this test.
Posted on Aug 28, 2009
  • 10865 Answers
SOURCE: fridge light bulb blown the housing is melted is
this is definitely not normal. It had to be caused by either a bulb of higher than 40 watts, or a situation where lots of items in the fridge were closely surrounding the bulb causing it to overheat.
Posted on Sep 01, 2009
Why does my daewoo fridge freezer works intermittently ?
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Jul 22, 2014 | Daewoo Freezers
Freezer is 4 months old, when we closed the door it used make a vaccum sound like it was sealing now it no longer makes that vaccum sound.
it doesn't mean the fridge door gasket isn't sealing properly, if just means it has worked itself into a permanent seal. if you aren't having any problems with the fridge, don't worry about it.
Nov 13, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Fridge light bulb blown the housing is melted is this normal fridge freezer 2 months old
Sep 01, 2009 | Freezers
Aug 25, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Hotpoint FFA97 freezer works but fridge does not
It seems to me that there is a leak of gas from your unit.This is if you have 1 compressor/motor)If there is two compressors on unit then it can be thermostat for fridge.Anyhow check if motor is running all the time and is wery hot, if it is there is to little gas in system .This should be covered by guarantee.Jan
Feb 13, 2009 | Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
101 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
