Question about Ovens Ovens
HOW DO YOU SET THE CLOCK? I CAN'T GET THE OVENS TO WORK
THERE ARE SIX BUTTONS FOR THE CLOCK AND TIMER ETC
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
If the clock is showing time you may have accidently knocked the auto button this will shut off the power to both ovens until the timer times out you must press the manual button it usually has a little hand printed on it. If you do not have any lights on the clock or oven it may be due to
1. a blown fuse or tripped power supply
2.Thermal cut out tripped or failure
3.A broken live or neutral wire isolate the power before doing any continuity tests.
4. A faulty timer.
Posted on Apr 30, 2015
How do I set the clock/timer to make the oven work?
does it have a clock button , if so press it then use the +or- buttons to set the time then press clock again
Dec 06, 2015 | Ovens
How do you set the clock on the Electrolux cooker?
You didn't specified the model of the oven so it is possible to set in a different way. There are several kinds of timer (with tree, four, five and six buttons) depending on the model of the oven. Here is explained how to set clock on the most common oven timer with three buttons.
First of all, the oven only operates when the time has been set.
When the appliance has been connected to the electrical supply or when there has been a power cut, the function indicator Time flashes automatically.
1. To change the time that has already repeatedly, until the function indicator Time flashes.
2. Set the current time using the "+" or "-" button.
After approx. 5 seconds, the flashing stops and the clock displays the time of day set. The appliance is now ready to use.
Dado
Mar 18, 2015 | Electrolux Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
Candy Electric Oven no power in oven/grill at all, only clock
is the timer set, most ovens wont work if the timer is not set
Apr 07, 2010 | Neff U1421 Double circotherm Electric Oven
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Cant fix the clock to work without the timer
if you are having trouble setting the clock times etc this is probably down to a worn bit generator this is the knob you turn to set the time they get dirty when using oven or grill and wont operate properly,the clock will need changing im afraid as there no way to open the clock without destroying it.
hope this helps
Jul 09, 2009 | Neff B1421 Electric Single Oven
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Ovens Logo
161 people viewed this question
Top Ovens Experts
rdjagger
ray gallant
Are you an Oven Expert? Answer questions, earn points and help others
