Rinse program not working - Washing Machines
  • Washing Mach... Master
  • 5,323 Answers
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
rinse program not working - rinse-program-not-working-fgv1ctnzjgewe3hu2qpqylbk-3-0.jpg
Posted on May 08, 2015
Why does Miele indicator stick on 'rinses'?
Hi dear. Your machine may have one of the three factors playing up.
1- Tacho generator or it's plug on motor
2- Motor carbon brushes
3- Power/ electronic module faulty. Thanks.
Mar 24, 2016 | Miele Washing Machines
Maytag centennial washer won't fill during rinse cycle
If the inlet works during the wash cycle or start program but does not work during the rinse cycle, then it is due to fault in the program. Select another program to confirm this cycle or choose another cycle. If the fault is the same on all the programs then it can be due to the controller unit.
May 04, 2015 | Maytag Washing Machines
Why does my Bosch Classixx 1200 Washing Machine rinse if I turn switch to rinse but will not rinse when automatically.
Are you on a delicates program that has no spin or is there a no spin button that has been pressed?
Check the manual to see what programs do what. You can usually find a manual on line if you have lost yours.
Dec 13, 2014 | Bosch Washing Machines
Whirlpool adp 952
Maybe try unplugging the unit and see if it will "reboot". You may have to start all over but would be better that it not working.
May 14, 2014 | Dishwashers
Rinsing and centrifug error
This unit needs a a drain pump
Jan 20, 2014 | Siemens Washing Machines
Constant beep, stops and switch to rinse program
Can be related to a fault in the program controller unit as none of the preset programs are working bbut the fault appears universal in all the programs.
The best you can do is to remove the panel and reset, check on the inlet valve and the sparying arms and pump. check for clogging in the drain or the pump which seems to set off the alarm.
Nov 12, 2011 | Dishwashers
Second wash/rinse cycle for heavy loads must be engaged manually. is there a way to set it to start automatically?
Possible fault in the program controller unit. If the menu can be set up manually then select the wash/rinse or drying seperately and press start.
In most machines this is possible to override the program just in case the auto mode does not work orr the said program has errors.
Apr 19, 2011 | Washing Machines
Our hotpoint bf168 has stopped working. The rinse
Petere
Did you have ny luck solving your problem as my dishwasher has the same error
Lorraine
Jan 11, 2010 | Ariston Technologies Dishwashers
Washer stops dead immediately prior to final rinse
this sounds like the conditioner solenoid, this is the cold water valve that works as the final rinse is suppose to work, just before the final spin, check valve connections for open circuit electrically, work safe unplug from power supply first, if i have helped please rate me
Oct 02, 2007 | Candy AQUA1000T Front Load
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
