Question about Sewing Machines
Problem with bobbin thread, it shows on top and the top one does not show. what could be the problem
  • Sewing Machines Expert
  • 460 Answers
One or other of your tensions is incorrect, either too loose or too tight. Start with the upper tension as bobbin tension is not usually the problem. Your manual will advise on how to do this.
Posted on Apr 30, 2015
The stitch which should be on the bottom seems to be on the top
Difficult question to understand and hard to address without knowing the machine & model.
Do you mean the bobbin thread is showing on the top of the fabric? If so, try loosening the upper tension and test. The mid-point between the high and low number is the most common factory setting for upper tension, although that should be adjusted to suit the fabric, thread, and your project. The ideal tension is reached when the upper thread and bobbin thread meet in the middle of the fabric (ie, bobbin thread does not show on the top and needle thread does not show on the bottom.
Nov 12, 2015 | Sewing Machines
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
Adjust tension
The tension of the top thread and bobbin thread are in a "tug of war". If the top is "winning" or too high then the bottom thread will be showing on the top of the fabric. If the top is "loosing" or too loose then the top thread will be pulled through the fabric and show a lot on the bottom. They must be evened out so the "tug of war" is even so the knot is in the middle of the fabric.
START WITH BOBBIN FIRST: Remove bobbin and bob from finger. When you have it adjusted right then the bobbin will extend one inch when you bob it. If you can't bob your bobbin you will have to make an approximate and replace. You may have to do this a couple times to get it right.
WHEN IT'S RIGHT: The bobbin and top tension are equal without being too much pull on both that causes the fabric to pull together.
Jan 31, 2015 | Sewing Machines
I have a Singer Futura XL 400 the bobbin thread is showing on the top
Tension between top and bottom is a BALANCE, and when the bobbin thread shows on top, it means that your top tension is tighter than your bobbin tension, so it is pulling the bobbin thread up above the fabric.
Loosen the top tension to balance it--it should only take a couple of "ticks"--no more than one number. Loosening the top tension, by the way, is AWAY from the "S".
Apr 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Futura troubleshooting
3 possible causes, Top thread is broken or top thread not fully in the top thread sensor or bobbin thread finish/bobbin thread broken.
Dec 22, 2013 | Sewing Machines
Bobbin thread showing on top
Lower thread showing on top is usually a lack of tension under. lower tension can be readjusted on the bobbin case but if U cannot readjust the tension, it means that ther is somthing between the tension blade and the bobbin case body. Remove the tension blade, clean and readjust.
Jun 26, 2012 | Brother PE770 Computerized Sewing Machine
I am using black bobbin threaad with white needle
In my experience, I can adjust the tension on my older machines (like my Singer Featherweights so that the needle thread will not show at all on the underside of the fabric (and the bobbin thread will not show at all on the top)--but I've found it nearly impossible to get the same degree of control on my newer (computerized) machines. It always seems that there is a touch of the needle thread showing on the bottom and a touch of the bobbin thread showing on top.
I'm not familiar with the MegaQuilter but I'd just keep playing with your tension control to get it as fine as possible.
Robbie
Aug 01, 2010 | Husqvarna Viking 1
Bobbin thread showing on top, automatic tension
It is possible the jam threw off the timing and this will need to be fixed by a sewing machine tech.
Try one more thing first. Lift the presser foot - this will open the tension control so the thread can properly seat into the control.
Re-thread the machine.
If this does not help, back to suggestion # 1.
Mar 25, 2010 | Sewing Machines
The bobbin thread shows
I am having the same problem and can't seem to find the answer. Please email me if you have found a solution!
Debr535@yahoo.com
Sep 30, 2009 | Singer CE-200 Quantum Futura Computerized...
I have a brother SE 270-d. my only problem is that while embroidering, the bobbin thread is showing through the design on the top. I have tried adjusting the top thread tension but no matter how I adjust...
Try making the material tighter in the hoop and check your bobbin to be sure it's a L (look at your instruction manual...it will show you which bobbin works and which does not. I say this because you have a tension problem...dont we all, Ha Ha!
Jun 22, 2009 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
