Question about Maytag MBR2258XES Stainless Steel
Fridge shuts down - Maytag MBR2258XES Stainless Steel
  • Maytag Master
  • 4,654 Answers
Here is a link to the parts manual=> MBR2258XES When you say that the refrigerator stops working you will need to tell me more. Lights on? Compressor and fans stop? Cooling stops? Control panel stops? Let me know by answering my post here, Thanks John T. Appliance 911
Contact
Posted on Apr 30, 2015
Active Smart Control Fridge Freezer E402B.Has just shut down.Going fine than it just shut down.No power.No lights,No compressor,No fans?????The power outlet that provided power to fridge seemed very h
first check the braker in the electrical panel for that line. the braker with the problem will be in the mid posison. reset it by pulling allway back and then all the way on...
Mar 30, 2014 | Refrigerators
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
The freezer on my side by side Maytag seems to run constantly and right at the door when you open it is a bit of frost build up not much but some. What is the problem?
If the frost is visible and the fridge does not shut down then the auto defrost timer can be faulty. set the thermostat lower and see if the fridge shuts down or else you must check the thermostat and the defrost timer.
Jun 14, 2011 | Refrigerators
I have a LG LRSC26923TT (2005) model. The entire fridge shuts down. The LCD goes blank and only the freezer light is on. Unplug the machine plug it back in and it fires up again. When the compressor kicks...
Were you able to figure out the problem or solution? i'm experiencing the same issue as of last night on the same exact refrigerator. Hope so!
Nov 02, 2010 | LG Refrigerators
Shut down once, some clicking noises. Now is runing fine.
Probably a bad compressor start relay.
Replace the relay before you condemn the fridge.
May 24, 2009 | Kenmore Refrigerators
Kenmore fridge with freezer on top/condenser bangs
check rubber mounts on compressor and also make sure fan is clear of anything that could be rubbing it
Dec 17, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Leaking fridge
The U shaped copper tube is most likely the drain tube where the water frost defrost exits and drains into a drain pan to be evaporated. Even thing is fine, do not shut it down nor call for service. If you hear it again wait twenty minutes and it should stop. Then check it and I'm sure you will find it is O.K.
Have a nice day.
Sep 16, 2008 | Refrigerators
Maytag MBR2258XES Stainless Steel Logo
61 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
