un plug from mains and turn off water supply and remove the water pipe. leave water off the unit. and plug unit back on at mains and turn on. using lowest setting turn on using this you should hear it moving about inside and a pump sound. if you dont hear a pump sound turn off and check that the drain pipe is not blocked. it sounds dirty but if you can blow down the drain pipe with the unit off it should be easy to blow down if not then its blocked inside. for that you will need to clean it out. here is a link to the pdf for the dish washer SAMSUNG DMS300TR User Manual hope this helps.
Please see this page I found in the owner's manual for your machine. Error codes F1 to F8 (except F2) require you to unplug the power and turn off the water supply before requesting service, so this will require a professional service person.
F5 is the fast and rinse LED
It simply means the lid motror current is to high during the start - The lid is jammed up or down. Or the electronic controller has failed!!
This means that the Dishwashers has detected a condition it needs to check.
Press "Cancel" to clear the display and to stop the beeping sound, then
try turning the Dishwashers off and on again.
If you still see the "SE error code," turn off the power to your Dishwashers and wait five
minutes before turning it on again. If you hear the beep or see the "SE error code"
when you try to washing again, please call your authorized
provider for service.
