Question about Haier Televison & Video
I have L32C300 haier lcd TV, its invertor board want to replace, where I should ask for the same in UAE
    Top Expert:
  • Haier Master
  • 74,473 Answers
There is no source in UAE.
Posted on Apr 27, 2016
electronick
  • 505 Answers
SOURCE: i need a electrical cord for my haier lcd 42'' tv
most of these use a standard computer type cable, its shaped like a D on the end and has 3 wires. some others are shaped like an 8 and are harder to find. check any computer store, or goodwill for a cheap one
Posted on Jan 22, 2009
bbl242003
  • 1637 Answers
SOURCE: 22" Haier LCD/LED TV -
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 16, 2011
gopakumarg43
  • 74473 Answers
SOURCE: repairing invertor board
Replacement capacitors can be bought from most of the electronic spare part selling shops.
Posted on Jul 24, 2012
leecwilkin
  • 25 Answers
SOURCE: Sammsung LA32R71BAX main BOard Rplacement Compatibility
You need to take the back off the TV and find the part number of the board you want to replace. Make sure you also write down the Rev. Number different boards may look the same but can have a different rev (revision) number. If the boards don't match there are always loads of boards on ebay for about thirty pounds
Posted on Aug 28, 2014
SOURCE: LCD Tv, no picture, no sound, power light only
What have you got? The inverter, the mainboard?
It'll be one or the other...
Posted on Jan 31, 2015
Volume on my Haier tv L32b1120 Goes up and down by it's self
There is little to No info on this TV. I would say, the signal board is the culprit. You may also call this the main board. Either way, it is the board containing the RF, RCA, and HDMI connections . Thanks for asking me. Matt of Martins TV.
May 21, 2014 | Haier L32B1120 32 LCD TV
Haier l32c300 screen blank sound ok
After checking the cables and connections if it still has a problem, take it to a repair shop.
Apr 03, 2014 | Televison & Video
L32c300 haier display problem
What is the problem you faces with this TV? Provide more details please. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Nov 01, 2013 | Haier HLTD7 7 in TVDVD Combo
Lg 42lg50 LCD tv has audio but no picture
The backlight is out most likely caused by either the T conn or the Invertor. The invertor is most likely you can get replacement boards from www.tvcircuitboards.com leave a email if your not sure what you need.
Jan 02, 2012 | LG 42LC2D 42 in. LCD HDTV
I cant get my HLTD7 to output tv via the av-out port. (dvd outputs to the av-out port no problems)
I'm not sure I understand your problem. If you are using a TV via the av/out, you are addressing another monitor to view the same video. Many stores will use this, and in this case there are several TVs with the same program. If this is not correct ask me again!
Oct 02, 2011 | Haier HLTD7 7 in TVDVD Combo
HOW DO I IDENTIFY THE POWER/INVERTER BOARD
The invertor board will usually have 2 connections, each with 2 wires (usually white and pink) that go to the screen, thats how you can identify the invertor board
The power board is just as easy to locate... Just follow the wires back from where you plug the power into the TV.
Be warned though, the power/invertor board can contain lethal voltages even when unplugged! Be careful!
I Hope this is the info you wanted.
Nov 23, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Sound but no picture.. Picture only for first few seconds tv is on
CHECK POWER SUPPLY BOARD FOR SWOLLEN CAPACITORS IF THERE ARE REPLACE THEM IF NOT REPLACE INVERTOR BOARD WHICH IS ATTACHED TO THE LCD PANEL.
Jun 24, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
I have Toshiba 15" lcd tv with vestel 17ips01-2 psu/inverter board.the tv will show a picture for a couple of seconds and then the inverter cuts out.
There are a few things that can cause this fault, but the most common is the High Voltage Capacitors that feed the backlights going bad. The invertor and power supply are on the same board (Vestel 17IPS01-2)
The caps are on the power supply board and are C355 & C356 (12pf 3kv) and C354 (4.7pf 3kv). If you replace these caps it will solve the problem in 99% of cases.
If replacing these three caps do not solve the problem then it may be easier to replace the power supply board... as fixing means replacing a tiny surface mount chip with loads of legs.
WARNING: The Power Supply/Invertor board can contain LETHAL VOLTAGES even when turned off and unplugged. if you are not sure, Pay someone to do it for you!
Aug 13, 2009 | RCA Mikomi 5290925 15 in. LCD TV
Direct TV universal remote control
Sir, there is no picture while switch on, but we can here the sound, have nay problem in the power supply, we can replace the parts, were can I get this parts, who is dealer in UAE. please write to me at hawkfo@yahoo.co.in
Sep 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Haier 26; TV Tuner
contact the Haier Service center in NY. www.asnyonline.com
May 25, 2008 | Haier HL32BG 32 in. LCD Television
Televison & Video Logo
67 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
