Question about New World Ovens
My new world plan 6 sbs gas cooker the oven wont light, the programmer won't work, no illumination, also the grill keeps blowing out, oven just stopped working when i was cooking a roast
  • david hall May 02, 2015
    i can only add that when i set oven dial to gas regular ? and open oven door it used to light automatically, now it doesn't, it won't even light manually
  • New World Master
  • 5,323 Answers
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
: rememberI offer free advice bcuz God is so good!
Posted on Jun 26, 2015
  • 883 Answers
SOURCE: My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
Posted on May 24, 2007
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
barkencoa
  • 3463 Answers
SOURCE: PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Posted on Jul 14, 2009
barkencoa
  • 3463 Answers
SOURCE: fan and grill works, grill actually cooks but oven
Without a doubt this is the element that is faulty.
It is located at the rear of the inner oven compartment behind a removeable cover.
Posted on Mar 30, 2010
SOURCE: New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Posted on Jun 03, 2010
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
Oven door open or shut when using grill?
Leave the door open in the broiler position, about 4 inches.
Jan 06, 2010 | Ovens
Gas mark nob not having any effect on gas levels in the oven seems like it is on its highest setting all the time? Also the ignition keeps clicking away all the time could this be a s/c on the wire from...
Time to change the thermostat. the cap tube sounds like it has been broken. If it has a temp control board, change the temp probe. The clicking sound, if unit is equiped with an ignition control modual, is bad, (not shutting off after sensing pilot) or sensor rod is dirty.
Dec 23, 2009 | New World G60m Gas Single Oven
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Sep 15, 2009 | New World G70m Gas Double Oven
New world tgo 70 grill
I have a TGO 70 for sale in Doncaster
Aug 14, 2008 | New World G60m Gas Single Oven
Ovens Logo
152 people viewed this question
Top New World Ovens Experts
paulcarew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
