E000246-0002 why comes conon ir 2200 Fotocopy machine
2 Suggested Answers
  • 191 Answers
SOURCE: fotocopy error!
check your copier fuser unit gear if the upper gears are in contact with the downgears or check your fuser element orclose your copier verywell. think this is helpful
Posted on Oct 05, 2008
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
Conon ir 2520 erore code e000750
Cause of the error code is a version mismatch with the bootROM file and the bootable/language file.
Re-launch the firmware flash and follow this order of flashing machine.
  1. Flash BOOT
  2. Flash SYSTEM
  3. Flash Language
  4. Cycle power and let machine boot normally.
May 10, 2015 | Office Equipment & Supplies
E000007-0000 error in diplay
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
fixya.com/support/t6195187-cannon_ir2018_system_error_e007
November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
Nov 02, 2010 | Office Equipment & Supplies
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Error E502-0000 CANON IR 2200
This problem generates from sorter/finisher ,try detached and disconnect the sorter unit from the machine
E502
Coming off of a sensor connector in an optional device is
detected:
•The door sensor, paper sort sensor, non-sort sensor, bin
outside paper sensor, staple position sensor, etc
Jun 30, 2009 | Canon imageRUNNER 2200
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
Solution :
Apr 29, 2009 | Office Equipment & Supplies
Fotocopy error!
Oct 05, 2008 | Office Equipment & Supplies
Cannon IR 2200
OK i am having the same problem but here is the solution that I have found online that I am going to try in the next 5 minutes:
waste toner container is placed left-rear side of the machine. Take out one screw,small cover will come out then pull out plastic container. Empty the container and clean the head really well as this can cause problems with the fuser.
good luck!
Aug 26, 2008 | Canon imageRUNNER 2200
E000014-0000
E000014-0000 ir 3300 canon machine solution
May 03, 2008 | Canon (6981A002AA) for imagerunner 2200,...
27 people viewed this question
k24674
