Question about Philips Televison & Video
Srp2003/27 button function modification instructions
Step by step instructions to modify button function remote works but direction buttons operate volume and channel with volume and channel function buttons
    Top Expert:
  • Philips Master
  • 74,251 Answers
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Posted on Apr 30, 2015
Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Nov 13, 2014 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Tip
How to program your Dish Network remote to your tv
Find your Codes for your devices here first: http://www.dishnetwork.com/customerService/troubleshooting/nhagent/default.aspx
The follow these directions:
OK, I understand that you need help programming your remote control to a TV or other equipment.
Note: After this procedure is started, if a button is not pressed within 20 seconds, the remote will end the procedure automatically. Simply start over again.
Step-by-Step Procedure // Step 1 of 6
Click on the following link to find the remote codes for your brand of TV, VCR, or other equipment. Note that codes for each TV brand depend on the remote type.
Step 2 of 6
Press and hold the correct Mode (TV, VCR, or AUX) button for about six seconds until all mode button backlights come on, then release.
Step 3 of 6
Use the number buttons to enter the three digit number (four digit for AUX mode) corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light.
For AUX mode ONLY: press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device.
Step 4 of 6
Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Step 5 of 6
To verify the code works, press the mode button. Try several different functions for that equipment. Some codes may provide partial function, or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
Step 6 of 6
If the remote still does not operate the device, perform the Power Scan.
If the remote still doesn't operate equipment, it may not be compatible with that equipment.
on Dec 02, 2009 | Televison & Video
I need the control remote code
irect Code Entry for GE remotes with 4 digit codes
The following is a short tutorial on entering the codes on GE 4 digit code universal remotes. See also this page for general GE remote code entering instructions!
Step 1: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 2: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink, then stays lit.
Step 3: Enter the 4 digit code for your device. After a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes!
Step 4: With your device on, press "CHANNEL UP" or "CHANNEL DOWN." If the device responds, no further programming is required. If some buttons do not operate your device, try one of the other codes for your brand. Note, when all codes have been searched the red indicator flashes rapidly for 3 seconds.
Code Search instructions
If your device does not respond to any of the codes listed with your equipment, or your brand is not listed, try the following steps:
Step 1: Manually turn on the device to be controlled.
Step 2: Press and hold the "SETUP" button until the red indicator stays on, then release.
Step 3: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink once, then stays on.
Step 4: Press the "CHANNEL UP" button repeatedly until the device to be controlled changes channel. The red indicator will blink, then stays lit.
Step 5: Press and release "MUTE" button to install the code. The indicator light goes off.
Generally it's best to store VCR codes under the VCR button, cable codes under CBL, and so on. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter any VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Sep 13, 2013 | RCA DRC230N DVD Player
I am having trouble programming my hype jumbo remote to my Emerson flat screen tv
I had problems with the instructions on how to program my Hype Jumbo remote. I finally figured it out. It was missing the step using the ENTER button. Here are the modified instructions:
TO PROGRAM
CODE SETUP
1. Manually turn on the device.
2. Aim the remote control at the device and press and hold the "CODE SEARCH" button until the LED indicator light shines, then release the button.
3. Press and release the "DEVICE" button that corresponds to the device you want the remote to operate.
4. Aim the remote control at the device and press the "POWER" button once. The LED indicator will search for the correct code blinking twice for each code.
5. The correct code will turn off the device. When the device turns off, press the "ENTER" button immediately.
6. Press the "POWER" button again to turn on the device. If it does turn on, verify the remote will function by changing channels, volume, etc.
Dec 11, 2012 | Televison & Video
Want to program my dish network remote to operate the phillips/magnavox TVs volume and turning it on and off. The TV is a 1998
Hello!! It should be pretty easy to get this programmed. Below are instructions to program the remote along with codes. I hope this helps!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code.
566
770
550
or if that doesn't work, here are the steps for a power scan. The remote scans the TV for the correct code.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Feb 27, 2011 | Philips Magnavox 20MT133S 20" TV
Where can I find a book on the different UVerse Remot tv codes for a new tv?
Hello
Universal remote code for Panasonic TV/VCR/DVD combo is
0437
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 19, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
RCR4358 I can't program my t.v. -- the instructions that come with the remote are ridiculous for an 83 year old woman who has still got her "buttons." Do you actually have some simple instructions? Thanks...
www.thompsontv.com
www.remotecodelist.com
  1. Step 1 Turn on the component you want to program.
  2. Step 2 Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  3. Step 3 Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  4. Step 4 Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  5. Step 5 Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  6. Step 6 Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  7. Step 7 Press and release the STOP button to save the new code.
Jul 10, 2009 | RCA Universal Remote Control
Will not turn off or on or change volume with remote
If you have verified the functions work by using the buttons on the TV then do the following.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If the remote does not work now then you may need a new one.
Mar 10, 2009 | LG 42LC2D 42 in. LCD HDTV
RCU410wms RCA Remote
http://remotefinder.rca.com/default.aspx?site=rca
This site will give you the codes;
Enter the codes 1> Press Hold Code Search until light stays on
2> press device button ie.TV
3>enter 3 digit code from site
4>Try Power button, if works great if not try another code
That's It!
Feb 10, 2008 | RCA Universal Remote Control
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
