Question about Plumbing
HOW DO I FIT NEW WASHER - Plumbing
  • 34 Answers
On more modern taps with no spanner flats it is very hard to fit a new washer.
However, if your tap does have spanner flats then you can turn off the main water, let pressure off of tap, undo with spanner and replace the washer.
Posted on Apr 30, 2015
Load noise in inlet valve when mains is attached when I turn on any tap in van thanks
possible vibration of the seat washer caused by the mains pressure sounds like a pitched squeal and varies with flow rate
if so get a tap reseating tool and recondition the washer seat and fit a new washer
or about the same cost fit a pressure regulator to the mains inlet pipe to reduce pressure to the van
May 02, 2017 | Washing Machines
I want to know how to fit a new belt to a hotpoint washer/dryer wd865
Remove the rear panel of washer, and tilt washer forward away from you with someone to hold it steady.
Fit the belt round the motor pulley first and slowly feed it round the drum pulley turning the drum pulley at the same time,
It will be very tight, so watch your fingers.
It may seem to be too small, but persist with it, and it will go on.
Nov 12, 2010 | Hotpoint Ultima WF865 Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
How to fit a new double valve on hotpoint first edition washer
Some valves are held by screws some twist on ,if the valve its self is okay you can Gently remove the Coil and fit the new one as its normally the coil that goes. It pull off with a srewdriver Gently otherwise valve may suffer damage...
Feb 08, 2010 | Hotpoint First Edition WMA12 Front Load...
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
Trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Drip tray for LG washer
all washers will leak for one reason or other / eather over load or shaking or something so be safe and get a pan that will fit and save your floor and ceiling
Dec 13, 2008 | LG WM2277 XL Front Load Stackable Washing...
I am trying to fit a new drum belt on a hotpoint aquarius vtdoo reverse action
You need to remove the top cover, remove the right hand side panel,ease the drum forward and fit the new belt.
It is very difficult to fit the new belt without the proper tool avialable from Hotpoint.
It can be done without the tool, but be prepared to stuggle
Dec 04, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Fixing new brushes
To fit new brushes to Hotpopint, you need to remove the rear panel if the washer.
There you will see the motor. remove the motor and fit the new brushes
Mar 27, 2008 | Hotpoint First Edition FEW10P Front Load...
Plumbing Logo
171 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
