Question about Health & Beauty
Tanning bed stopped working when i dropped one of the fan wires it hit metal and bed shut down checked breaker and thats good wondering if maybe theres a fuse in the bed
    Top Expert:
  • Health & Beauty Master
  • 45,297 Answers
Maybe there is google make and model
Posted on Apr 30, 2015
I got a tanning bed off someone it worked good moved it to my house i wont come on
These days tanning beds are considered potentially as dangerous as sunbathing. Much has been written about them and it would be wise to do some research before you start using it.
Modern tanning beds might include some electronics but originally they were simply a collection of fluorescent lamps, a timer and a selector switch and probably at least one safety device such as a fuse or a thermal breaker.
The circuit should be fairly straightforward and easy to follow and check which will be the only way to discover the fault using a multimeter to verify the supply and discover where the current flow stops.
May 29, 2017 | Health & Beauty
Fans keep running after bed shut off
The fans will run until the temperature has been reduced. Just because you shut it off doesn't mean it gets immediately cold. It's just like the fan on a car that keeps running after the car stops.
Jan 03, 2015 | Wolff Sunvision Pro 24S Tanning Bed
Tanning bed wiring diagram
For a wiring diagram, contact Sunstar directly.
Sep 16, 2017 | Health & Beauty
240 v should work right?
no, voltage is not the issue, what is the amperage you need. If you need more than you have, then you could have 2000 volts and it will not work. Also your taking AC to AC, or DC to DC. There's a big difference in what you need for each.
look up Ohms law for for the calculations needed for voltage vs amperage using one socket.
good luck
Apr 30, 2013 | Health & Beauty
My sunquest pro 14 Se came on bulbs lit and shut off and will not come back on
Have a trained technician to check voltage going to bed and for blown fuse on back of bed. You may have a circuit breaker tripped, but I would bet that you have checked that.
Feb 02, 2013 | Wolff Sunvision Pro 24S Tanning Bed
1986 sca wolff 328sl tanning bed wont stay running
Consult manufacturer. You can track that down online. You may have a over-temp switch inside the bed. If so, then either the switch is bad or the bed is getting too hot. Have a trained technician to check voltage going to bed, if voltage is wrong that can cause bed to overheat. Make sure all fans are running, replace any fan that is not running. Clean all dust out of bed with vacuum and brush while you have it open.
Dec 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
How to repair a tannin bed model H-24RSB
Have a trained technician to check for wrong voltage going to bed. Then for burned out components and wiring inside the bed. Turn power off to bed before doing this.
Nov 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
I have a sunvision 24 tanning bed and it isn't coming on what do i do
Have a trained technician to: Check main breaker, check that bed is getting power to it, check for bad fuse on back of bed, check for burned out wiring inside of bed at main relay, check that the timer is good.
Aug 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Owners manual on sunstar zx30 tanning bed
I have a sunstar speed system tanning bed, it has been wired/connected and when you flip the power on in the breaker box the only thing that is displayed on the digital panel is 8.8. You cannot turn the bed on!! You cannot do anything! PLEASE HELP!!
Oct 13, 2010 | Health & Beauty
NBM fan is too noisy. Is it possible it has overheated?
Most Likely a bearing is going bad in the fan - unfortunate with such low hours - but probable. Make sure nothing is hitting the fan blades on either side of the fan - if not, then definitely a bad bearing and the fan will need to be replaced. Wolff Tanning carries them in stock at www.wolfftanning.com
Jan 21, 2009 | NMB Technologies Fan Motor Case Cooling...
Health & Beauty Logo
157 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
