Question about Health & Beauty
Fan wasnt working took a look at it wire was loose ended up dropping one of the wires and it hit metal and now bed dont work and i checked breakers and thats not the problem
Sunal tanning bed
3 Suggested Answers
  • 60 Answers
SOURCE: Is tanning on a tanning bed just like tanning outside in the sun?
No - it's very different as outside, various objects block the direct rays of the sun and allow you to be outside in the sun for a lot longer. Tanning beds are very instense. You should not be on the bed for longer than 10-12 minutes for your first sessions and be very careful about adding extra time.
Posted on Feb 18, 2013
  • 44225 Answers
SOURCE: tanning bed stopped working when i dropped one of the fan wires it hit metal and bed shut down checked breaker and thats good wondering if maybe theres a fuse in the bed
Maybe there is google make and model
Posted on Apr 30, 2015
House wiring
TAKE EXTREME CAUTION WHEN WORKING ON LIVE WIRES!
THIS WORK SHOULD BE PERFORMED BY TRAINED ELECTRICIAN.
REMOVE BREAKER FROM BACK OF PANEL & INSPECT FOR LOOSE AND WORN CONNECTIONS THAT CAUSE BURNS AND MELTED METAL CONNECTORS.
Jan 27, 2015 | Electrical Supplies
95 neon dash lights work but guages dont work at all.
Lets start at the beginning. Did you check the fuse and the circuit that powers the gauges ?
Oct 05, 2012 | 1995 Dodge Neon
Skil HD77 that blows breaker no matter which plug in I use. This saw was bought on e-bay and does not appear to have abused except for new plug on very short cord. I checked end of plug and it appeaers to...
there is a direct short somewhere, recheck the plug end for correct wiring and if OK then it is in the cord or the motor itself, I would think the cord or plug first.
Sep 01, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
Just quit. Worked fine one day. Next day went to turn it on and nothing happened. Fan is little over a year old.
Control switch, circuit breaker, or loose wire are main suspect.
Rarely does a motor just stop working.
Check circuit breaker.
Open control switch and test for power and check for loose connections.
Install ordinary on-off switch and see if function resumes.
Check wire connections at fan.
Jul 11, 2011 | Air King 9166 20" Whole-House Window Fan
I have a pioneer deh-p3600 cd player in my car and it recently stopped working. It would go on and off when I drove around after hitting bumps and such but now it doesn't work at all. Any suggestions.
pull it out and look for poor connections. maybe wasnt installed correctly and wire connections are breaking loose and or touching metal, tape up all connections and if problem is still there check all wiring for insulation missing and tape that area up , also make sure black wire(ground) is securely bolted down to metal!
Feb 18, 2010 | Pioneer DEH-P3600 CD Player
Power light doens't go o
Plug a working lamp in the washer power outlet. If it lights, the problem is within the washer (look for a breaker button on the back of the machine). If the lamp doesn't work either, look for a bad breaker, a loose neutral wire connection, or loose wire connection on the breaker. Check the wiring on the washer end as well.
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wall switch and remote quit working for fan and light
Simple things to check - sometimes the vibration from the fan will cause the wires to come loose. Drop the fan and make sure both wire nuts are secure - take the opportunity to check and make sure you have voltage (using a voltmeter or a 110v test light) at the junction box. Do you have lights on the fan? Do they come on? If you have power to the fan, something is amiss inside the fan such as a faulty speed switch or connection.
Jul 20, 2009 | Hampton Bay 24750 Huntington III Ceiling...
95 GMC safari electric windows dont work
the cur kit breaker was shorted out gave me 12 volts still but when I used a volt light and touched the out side metal housing the light lite up that means a short so I replaced the breaker and wala they work.
Dec 01, 2008 | 1995 GMC Safari
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
