Question about Pioneer Audio Players & Recorders
I have a pioneer vsx d503s and the standby light is on. But the receiver will not come on
  • Petra May 06, 2015
    Sorry for the delay. Typically, I would say, "With a DVM on the DIODE scale, and NO power applied to the receiver, check the Base-Emitter; Base-Collector; and Emitter-Collector junctions on ALL output Power Transistors. (They will all be bolted to a Heatsink). You are looking for anything less than approximately .450V (450mV). It would be best if you could send me the results, if you are unsure how to evaluate them". HOWEVER, this receiver uses (2) PAC014A & (1) PAC015A Output ICs, it would best if I send you a copy of the Service Manual. It contains all the diagrams and flow charts you need to troubleshoot this receiver.
    petrostherock@gmail.com
    -Petra
    Problem Solver:
  • 12 Answers
I sounds like you may have a problem in either one of the Regulator circuits, or, one of the Power Amplifier outputs. If the protect circuit detects DC or Low Impedance on one or more of the speaker lines, it will not fire up the high power section of the power supply. Further troubleshooting will require some working knowledge of power amp and power supply circuits. I've got a .pdf copy of the Service Manual if that will help you.
Please let me know what your level of troubleshooting ability is, and whether the manual will help you.
-Petra
Posted on May 02, 2015
  • Anonymous May 03, 2015
    I am very good at trouble shooting. Also good with wiring diagrams.
SOURCE: pioneer VSX-D503S receiver-no sound coming
it might need to be rregrounded
Posted on May 27, 2008
SOURCE: standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Posted on Oct 14, 2008
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: diagram of pioneer receiver vsx-454 to show wire hookups
This site has the manual for downloading. You need to register but it's free.
Posted on Mar 02, 2010
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
Pioneer vsx 915 blue light flashing
Time for a repair shop to look, clearly the amp is down, it has failed. Have a qualified tech look at and get a repair estimate.
Dec 15, 2012 | Pioneer VSX-915 Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Pioneer vsx-01 receiver, standby light burned out. Button works fine, just no blue light. Pioneer sells a replacement standby button......is this easy to install and will it solve the problem? Do you have...
the light is an ledt they very rarely go bad ..to confirm its bad you must first see that the led is getting power --a voltmeter one end to the frame of the unit and the other to either lead on the led will confirm if its bad or not a typical led will run on or near 3 volts dc... if theres no power at the led than the problem is elsewhere
Aug 30, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
My Pioneer VSX-D704S WILL NOT POWER ON. WHEN I PUSH THE POWER BUTTON NOTHING HAPPENS. THEN THE STANDBY LIGHT COMES ON.
It is in protection and will need to be serviced. Find a local AUTHORIZED pioneer service center.
Jun 10, 2009 | Pioneer VSX-D704S Receiver
VSX-D409 - Standby Light - Does not Power On
Hi...
Make sure all the speakers are connected properly at BOTH ends.
If still **** then seek a service tech
Nov 27, 2008 | Pioneer VSX-D509S Receiver
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
231 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
