Question about Xerox Workcentre 7335 All-in-one Laser Printer
Our xerox workcenter 7335 fault code 024-346 and copy service is disabled
2 Suggested Answers
SOURCE: our xerox workcenter 7235 fault
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Posted on Aug 05, 2010
Dear All can any one tell me solution for this Error please XEROX 7228 Workcenter code 004-346 waiting for your kind replays
04.346, 04-562 Transfer Belt Home
The IBT Home Sensor does not detect the Belt Home signal.
If this fault is declared 3 times in succession, print mode will be disabled. In order to
clear this condition, reset NVM location IOT/Finisher 1221 to 0 in dC131.
Sep 15, 2015 | Xerox Office Equipment & Supplies
Fault Code: 016-405 Xerox WorkCenter 5335
This FC (fault code) 016-405 means that there is an error with your security certificates on the 5335 .Copy the link below into your browser and type 016-405 in the search field and it will provide guidance on how to resolve this issue.
NOTE When working with security certificates on Xerox equipment it is recommended you call them for support or have your IT person investigate, this is because if you delete any certificates and not initialize them again you can break some custom services installed on your machine.If you;re not sure if you have custom services running please call your IT department or Xerox for assistance.
http://www.support.xerox.com/support/workcentre-5300-series/support/enus.html
I hope this helps ...
Mar 06, 2015 | Xerox Office Equipment & Supplies
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
Aug 05, 2010 | Xerox Office Equipment & Supplies
I need to print standard size 10 envelopes. Where/How do I load them? WorkCentre7335
Some setup will be necessary both on the WorkCenter and in your software. I will describe these steps and leave you with a link to Xerox to check as a reference:
On the WorkCenter 7335
1) In the Bypass tray, load the std. 10 envelopes width-wise with the side to be printed down, flaps tucked in and with flaps entering the printer first. Slide the guide to just touch the edges.
2) Touch <Change Settings> on the WC 7335 screen
3) Select "Envelope" from the "Paper Type" list
4) Select "No. 10 Env" from the "Paper Size" list
5) Select "Save"
6) Select "Confirm"
In your software:
As you did not specify your software, it is important to note that whatever application you are using, the following settings must agree with the steps above:
1) Feed method = Face down, Clockwise rotation
2) Feed from = Bypass
These options may be chosen in different ways depending on your software program.
You may review these setup steps for Word here:
Xerox WC 7335 Print Size 10 Envelope
Jan 25, 2010 | Xerox WorkCentre M118 Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Ow to change resolution in xerox workcenter pe16 scanner
resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
May 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox Workcentre 7335 All-in-one Laser Printer Logo
190 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
