Question about Garden
Sometimes I smell the burning, then make noise, why not work now? Only 2 years
  • 1462 Answers
SOURCE: Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Posted on Aug 09, 2008
  • 2920 Answers
SOURCE: freezer not freezing and burning smell
it may be the compressor overheating it could be the relay but if the compressor is hot then you are low on freon and need to have it recharged
Posted on Jan 26, 2009
  • 17 Answers
SOURCE: The dryer smells like it is burning. It is only 2
it could be a number of problems, but i would suggest it is the heater element for your dryer, or an outside chance of the drum motor, it may also be as simple as one of those items i mention being covered in fluff build up from drying,
if you can remove the back cover or the base cover you should have access to the parts mentioned, give them a good hoovering out and see how that goes.
what sort of machine is it ?
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: Our JVM1850 makes strange noises,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 16, 2011
  • 552 Answers
SOURCE: Our less than 2 year old dryer is making an awful
the motor could be bad.
Posted on Mar 08, 2011
Burning smell and noise from vacuum
The roller head may be turning, but something could be rubbing and causing the belt to slip slightly. I'd remove the belt and beater bar and look for foreign material that is stuck
Jan 07, 2015 | Sebo ET-1 Powerhead White
My heater was just installed and it smells like burned stuff. What should I do to make the smell wear out, do I leave it on with windows open?
Check the installation paperwork and see if it says anything about it. Heaters have been coated with oil in the heat exchanger to prevent rusting. Sometimes a heater will be produced in the year 2010 for example, but doesnt sell until 1 or 2 and maybe 3 years later after that. So it might sit in the warehouse for a long time. The oil will help the metal from corrision. The installer is suppose to tell you that when you first turn on the unit, it will smell like burning (oil). Open the doors and some windows until the smell goes away. (15 to 30 minutes) This is normal. Now if the smell wont go away maybe something fell inside and is burning!!! RuNNNN!!! no may have to open it up to check... rare case
Mar 25, 2010 | Williams 1403622 Gas Compact Heater
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
Vacuum making high pitched noise and smells like motor is burning
try repair first for quote and if too expensive then replace. 5 years is about the average life span.
Jul 01, 2009 | Dyson DC14 All floors Bagless Upright...
Smells like wires buning
Motor may just need new brushes, Cooling vents may be clogged with dust. or bearings in the motor or front roller maybe bad. Causing excessive drag
blow it all out with compressed air or shopvac
look for external brush caps (2) oppsite from each other take them out to be sure they slide freely, sometimes one gets hug up and doesn't make good contact
Mar 12, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Grinding noise,unit stopped, burning smell?
broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Oct 07, 2008 | Admiral AW22 Top Load Washer
Aug 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Burning smell
The sulphur smell is the result of the emmisions control system. I have an 06 Expedition with the exact same engine and emmisions system as yours. When the engine is cold, you don't smell that sulphur smell, but as soon as the engine gets to operating temperature, the exhaust gasses smell sulphury. Nothing wrong with your ride - they all do that. The dealership sometimes spray the underbody with some type of rubber to protect the vehicle against rust. This rubber stuff sometimes get sprayd on the exhaust as well and then you will smell "burning tires" after driving the vehicle. This will go away after a few thousend miles though.
May 15, 2008 | 2008 Ford Expedition El
Dryer not working all the time
99% of the time , a buzzing motor means the motor is almost burned up. Especially when you can smell it. A burnt motor calls for more current due to the laws of electricity and this overheats the motor windings and this is what you smell. If you are lucky, one other thing can cause a motor to buzz. Something is binding somewhere and the motor is not strong enough to turn the shaft. You would smell this also, but if you can find what is binding it and remove it, then you should be ok if you have not used it too much with it smelling. Look for a sock or wash rag tangled inside the dryer between the drum and the inner walls. This extra "drag" would cause the symptoms you are seeing, but something tells me that you have a burned up motor.
Mar 03, 2008 | Dryers
Garden Logo
507 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
