Question about Canon Powershot A2200 14.1mp Digital Camera silver 4941b001
Battery charger is not working . where and how it can be repaired ?
    Sergeant:
  • Canon Expert
  • 488 Answers
It is probably cheaper to just replace it with a new one.
Posted on May 11, 2015
I have a 18 volt nI cad Bosch charger .can I get it repaired and by who
Have you tried a tool repair service? My husband is always seeking advice from the tool professionals. Due to constant use, his chargers stop working often and, although he is a handyman himself, there are times when his own knowledge isn't sufficient. bourgetbros com
Aug 07, 2015 | Bosch Drills
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Nikon L22 camera will not power with new batteries
I would see if the camera works with disposable batteries. If it does, your battery charging circuit may be faulty. Are you charging the batteries in the camera or in an external charger? If it's in the camera, buy an inexpensive external charger and see if that works. If you eliminate the charger as the cause, the camera will probably need to go in for repair. Contact the Nikon Repair Depot listed in your camera's manual or on the Nikon USA website. They can give you a repair estimate.
Nov 28, 2012 | Nikon Coolpix L22 Digital Camera
MAKITA LXT BL1830 18V LITHIUM-ION 3.0AH BATTERY
If the charge count on the batteries is under 300, Makita will replace them. Makita has a known defect in this battery that causes the battery to shut down before it is dead. So as of now they are exchanging ones with low use.
If they are truly defective and makita won't replace, you have to open them, find the dead cell or blown fuse, and replace. Search youtube makita battery for a video on repairing this battery. But once the red and green lights on the charger flash, the the battery can't be charged on a Makita charger -- it's been locked. So use a third party charger.
Apr 18, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
How much to fix my Nokia 8800?
i had the same problem with my nokia 3600.. i replaced both my charger and battery.. but it didnt work. then i gave it to service .. the service guy got 400 indian rupees to repair it.. now its working fine
Apr 11, 2010 | Cell Phones
Acer Aspire 3000 notebook: 1) monitor displays horizontal random lines. This can be fixed by clamping the bezel to the lid, at the position of the lid release catch, using a bull-dog (spring) clip. It...
Monitor: if the inverters were blown, you would be unable to use clamps as a workaround. I suspect a lose or broken contact to the display wafer caused by rough handling of the laptop. This is delicate stuff, you cannot repair without specialized tools and usually its simpler and cheaper to swap the panel for a new one.
Charger: try to remove the battery and connect the charger. Check if the laptop starts now. If yes, the battery probably reached its end of life and drains so much power during inefficient charge that the power supply has not enough extra strength to run the laptop on top. Only one hour of run time hints to a degraded battery, too.
Replace the battery with a new one and check if the problem persists.
If the laptop does not run with charger and without battery, the power regulation in the laptop is fried.
Since there is more than one defect already (replacement batteries are not cheap, too), you should consider to contact Acer repair services. In my experience they provide reasonable priced repairs; they give you a quotation for a small fee before they actually repair the thing, so you can decide how to proceed.
Check if they have a repair site in your vicinity. I went to Acer Hong Kong in 2005 with similar problems and a few days later picked up my machine, repaired to my satisfaction and with a full report what was wrong.
Feb 07, 2010 | Acer Aspire 3000 Notebook
Charging
Then there is a problem in the charger socket. Try a different charger from a friend to eliminate the charger. Does your charger work elsewhere?
Aug 14, 2009 | Nokia 6120 classic Cellular Phone
Charger not recognized
Folks.
The issue with most of the Dell charger issues rekated to a new charger not being able to charge the battery is the fact that Dell has a screwy proprietary circuit design in their laptops and chargers.
It seems that the Dell laptops are designed so
only Dell chargers will work. While other
brands of chargers will power the laptop when plugged in,
they will not charge the battery.
They do this so they have a monopoly on their chargers and thus can charge a frickin' fortune for their, Dell chargers.
Want them to change this? don't buy Dell products for a while. If enough people ban them, they would change this **** overnight!
Jul 07, 2009 | Dell Inspiron 1501 Notebook
Inquiry
Try to switch it on connected to an AC charger, if it switches on , then it is a battery problem. If not, it may be the AC charger, or oxide in the charger contact.
I sugggest also going to a local phone repair shop, and eventually testing a different battery and a charger.
If the battery works, replace it, if it is not the battery or the AC charger, then ask the fee for repair. Usually it is the charger or the battery.
Oct 14, 2008 | Sony Ericsson P910i Cellular Phone
Pewer problem
Jul 09, 2008 | Sony Ericsson P910i Cellular Phone
Canon Powershot A2200 14.1mp Digital Camera silver 4941b001 Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
