Question about Mophie Juice Pack Powerstation Mini Micro Quick Charge External Battery for Smartphones and MP3 Players
The charging port appears to have broken off board, this new never chsrged but out of warrenty. how do I get the metal case off to attempt to repair charging port?
    Genius:
  • 1,585 Answers
Its probly solderd in place
Posted on Apr 30, 2015
Have to push power adapter hard for tablet to charge
The power port is damaged - most likely the solder joints are loose or broken. You need to find a store where someone can open the case, order the new part for the tablet and then solder the new power port to the board.
Then it will be as good as new.
I have replaced power ports on laptops, phones and tablets.
May 24, 2015 | Tablets & eReaders
My almost new under warrenty galaxy android 10.5 tablet: usb cable end will not fit into the port anyhmore..it used to..is the port hole broken?
Do you have an Android phone?
If so compare the charging ports.
There should be a small plastic bar in the port with connectors on it.
If this bar is missing or damaged, then it would need replacing.
Most phone repair shops can repair this but from past experience it will probably cost between £100 and £200 to repair.
It is NOT covered by warranty unless you have a very helpful staff member from where you bought it.
Samsung usually class this as user damage and will not repair for free.
See picture for the plastic section which may be damaged.
Feb 06, 2015 | Tablets & eReaders
How do I repair the USB PORT on a ACER ICONIA B1.
Step 1 - Back Case
  • To start, gently separate one corner of the case using the black spudger.
Step 2
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
Step 4
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Step 5 - USB Port
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
Step 6
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
Step 7
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
Step 8
  • Pull up the metal panel just enough to allow access, then remove the USB port.
Oct 29, 2014 | Acer Iconia B1 7-Inch Tablet Black Dual...
Where can i get my galaxy s charging port fixed and how would the port become loose?
If it's loose it is probably broken away from the internal circuit board. A common problem. People accidentally knock the plug sideways and they only have fragile connections.
Get a technician to resolver if possible or take to Samsung repair centre.
May 02, 2014 | Accessory Export Samsung Galaxy S i9000...
Phone line not working on v510
Check the telephone port of your VX510. If it is moving or loose, pretty much you have a broken traces on the bottom board, and it can be repaired by opening the plastic casing and solder the broken port back to the board. But if you open the plastic case, a TAMPER MESSAGE will appear in your unit and only can be cleared by reloading the Verifone Tamper Removal Software. Hope this will help you a little bit and if still needs help you can call us at (775) 358-2922 ask for Randy. Thank you http://freshpoint.org
Dec 19, 2012 | VeriFone Omni 3700
Vostro 1510 laptop. Motherboard need replacing?
The best available solution is not an happy one, but the cheapest. E-bay will usually have your part for a fraction of the price ($100 or less for the entire mobo), but then you need to take the computer apart and do the replacement work. Easy....... but terrifying!!
Apr 20, 2010 | Dell Vostro 1510 Motherboard System Board...
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
Mar 16, 2010 | Garmin nuvi 200W GPS Receiver
SUPPY POWER DOSNT WORK
Most likely the power jack inside the laptop has broken away from the PC board. This is a relatively simple repair once you get to the jack itself. The entire laptop needs to be dis-assembled to get to it though. I would not recommend any attempt to repair this unless you have experience with laptop dis-assembly/re-assembly. When I get this type of repair, I usually charge an $100 flat fee that includes the hardware repair as well as a systems check/cleaning.
Dan
Mar 24, 2009 | Acer Aspire 1664WLMi (LX.A3005.094) PC...
Broken Mini-USB Port
This is a very common problem on all GPS systems. The USB port comes loose and disconnects from the motherboard. Sometimes we can re-solder it if it did not come off completely. Sometimes the complete board has to be replaced. I do this all the time for my customers. Your unit must be opened and inspected by a competent repair person (like me) to determine what needs to be done.
Mar 19, 2009 | Garmin nuvi 255W GPS Receiver
USB Flash drive broken
Have to be taken to either your local PC repair shop or sent back to the manufacturer. I would send it back to the manufacturer because they are more familiar with your system. There is nothing you can do to fix it has to be fixed on motherboard.
Don't forget to rate this solution..
Jan 11, 2009 | Computers & Internet
Mophie Juice Pack Powerstation Mini Micro Quick Charge External Battery for Smartphones and MP3 Players Logo
132 people viewed this question
Top Mophie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mophie Audio Player and Recorder Expert? Answer questions, earn points and help others
