Hi Ronald Winston, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi Ronald Winston, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
email netfix direct & ask them to resend ur login details u will be asked a security quiestion before gaining access but they will walk you thru the process
The easiest way to recover entry to your router is to hard reset the router by using the tip of a pen and pushing it into the reset button on the router for at least 15 seconds. The router should then reset to defaults, which includes the user name and password. The default user name and password should be listed somewhere on the router. If it isn't, then search online with your router's model number to find the default user name and password and default IP address. For example: IP Address: 192.168.1.1 Username: admin password: password
Your router may be different but it should be somewhat similar to my example.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
You insert a certain disk, I forget the name of it I think it is Disk (C in the Computer section.If you are logged on, go to User Accounts and click Manage Users and change the password from there. Hope this helped.
Restart your computer press F8 button. New window will appear in that select the safe mode it will automatically login to xp. And then you can change password or remove it by control panel -> user account. Through this you can login in to your system. Any problem just contact me..
