Question about Bose SoundDock Portable Digital Music System (SOUNDDKPORTW) Docking Station
Why can't my Bose soundDock portable be put off when charging. How do I put it off.
  • 11 Answers
SOURCE: Bose SoundDock burned out two of my iPods - a Nano and a classic.
um ur sounddock might require that u place the white docking piece that came with ur ipod to be place b4 the ipod is docked if not u may ruin the dock and the ipod usb port this is done because different generation ipods(nana and touch and ...) have different shapes so the entrance for docks may require to be eleveated or reduce in gradient basically if the dock isnt made for the specific ipod or u dont know just put the white piece in
Posted on Oct 05, 2009
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Posted on Nov 24, 2009
SOURCE: docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Posted on Dec 03, 2009
  • 51 Answers
SOURCE: I need the Bose SoundDock schematics
No, but I have repaired many without a schematic. Aside from damage, there are abiot four basic failure modes. Tony
Posted on Feb 22, 2010
  • 17 Answers
SOURCE: Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Posted on Mar 09, 2011
I just purchased bose sound dock series 2, it does not play without electric power after charging for over 9 hours. Could it be the battery is dead? my serial no 04937191222080IAE. Plese check for...
Go online to Bose, contact customer support and the technical department for answers, or take it back to the place of purchase and request a exchange.
Apr 20, 2012 | Bose Audio Players & Recorders
Bose SoundDock got wet
No! the Bose unit would need to be serviced by them, there are no authorized technicians outside of the factory, plus they have the needed parts.
Apr 08, 2012 | Bose SoundDock Portable Digital Music...
My bose sounddock portable system suddenly stopped working so I thought it needed charging, when I plugged it back in to the mains it wont charge and no light comes on the system at all it's totally...
Guys - she has the protable!! Hi Fiona, the best bet is to visit www.invebo.com and check the SounDock Portable diagnostic video. (Repair video is there too) Remove the battery and plug the power in., If you get a beep-beep sound then the unit has power and is booting up so you need a docking connector replacement kit. . If there is no beep beep then it is the power supply or the main unit. (Try a different power supply) . If it works normally then it is the battery - get a new battery. Hope that helps.
Sep 30, 2011 | Bose SoundDock Portable Digital Music...
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
My Bose Sounddock stopped playing. I believe
mostly the flatcable from the dockingplug to the ampifier has a bad connection ,try to connect it again or resolder the contacts
Apr 19, 2010 | Bose SoundDock Portable Digital Music...
Bose Sounddock won't play iPod touch
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Sep 13, 2009 | Bose SoundDock Portable Music Pack Docking...
I've lost the power charger for my portable sounddock
If you call bose directly they can sell one to you for around $60
Jul 03, 2009 | Bose SoundDock Digital Music System for...
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
Bose SoundDock Portable Digital Music System (SOUNDDKPORTW) Docking Station Logo
192 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
