Question about Maytag Washing Machines
Where can I buy the water inlet hoses for Maytag Washing Machine
    Genius:
  • Maytag Master
  • 1,585 Answers
Any good hard ware or plumbing merchant
Posted on Apr 30, 2015
Water is pulsating entering a Maytag MTW5821TW0. It's doing it in the cool warm and hot mode not in the cold. Is the water inlet valve or water temperature switch the problem?
Check the inlet screen on the hot water hose at the inlet to the machine and the shutoff valve too. It's possible it's partially plugged.
May 10, 2017 | Maytag Washing Machines
Washer fills extremely slow. Hoses are fine water
Hi, check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
I have a Maytag front loader Mod. MFW9700SQ1 - I get an error code of H and then F flashing. The machine stops washing. What could be the problem?
Hi
Error HF means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If the machine is not filling then check whether both valves at water source are turned ON and inlet hose are not plugged. If the machine is filling fine then chec the pressure switch hose and the drain hose for siphoning (also make sure water is not flowing back to the machine from drain hose). Check wire harness connections to: Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Hope this helps... Please post back if you need more information.
Daniel
Jan 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
The washing machine won't fill up with water but it will spin. It won't rinse as well
try connecting the cold water hose to the hot water inlet on the machine then switch the water inlet to hot and see if the water starts to fill if it does then your cold water inlet valve is broken and needs to be replaced
merry christmas
Dec 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Neptune does not dispense hot water. Just a trickle. Warm and cold are OK
I'm not a repairman, only a "doityourselfer". Try some or all of the following:
1. Check water valve to see if it full open.
2. Check the hot water hose inlet on the back of the machine. Look for a strainer that may be clogged in the hose inlet (turn water valve off first).
3. Check hose for kinking.
4. With the hose disconnected from the washing machine, try running some hot water through the hose into a bucket just to verify the water is available.
5. With machine set to hot water wash, start a cycle and listen for the hot water solenoid to "click" when the machine is started (some solenoids are louder than others so listen carefully). If water begins to trickle in when you here the click then the solenoid is probably working properly.
May 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Dryer operates; washer failed during end of spin cycle. Now washer will not fill or operate. No motor activity.
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
There's no water at all If there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
May 07, 2009 | Kenmore Washing Machines
Frigidaire washer
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
May 04, 2009 | Frigidaire Washing Machines
Maytag neptune shutdown
You need to first check your water inlet hoses & make sure they are not kinked or plugged.(verify by disconnecting hoses & opening to make sure water flows. If ok. Then check for cold water operation at fill valve. If no cold water after a few seconds then the problem is the water fill valve. If this doesn't help. Post findings for further troubleshooting.
Bill
Apr 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Maytag top loader washing machine stooped pumping water out
HI
  • Thank you
    Dec 07, 2008 | Washing Machines
    Washing Machines Logo
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
