My ecox inverter some time stop the compresos and start blowing only fan air. The console retry to turn on the compressor and it does but when it get to turn the last light of the compressor y turn off al the light and start blowing fan air. It seem that the compresos canot keep on. It works sometimes without a problem.
What could be the problem?
Sometimes these AC's need to be removed and given a damm good cleaning with a spray hose, and any filters replaced. Clean the internal fan(s).
This can sometimes fix overharting of the compressor or misleading air temp sensing..
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Problem #1:Outdoor condensing fan motor has stopped running. This problem
could be caused by a bad motor run capacitor.
If
your motor capacitor is not the problem, then more than likely you need a new
motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard
to turn then you probably need a new motor.
Problem #2: Air conditioner compressor will not start. When power is applied
to the air conditioning outdoor unit the fan starts, but you hear a sound like
the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then
all you hear is the outdoor condenser fan run. The compressor is locked and will
not start. What is happening is the compressor is trying to start, but because
the compressor motor is locked it tries to start for a few seconds and then
because of the high amperage being drawn goes off on internal overload. The
internal overload protects the compressor windings from overheating and burning
up. I see this many times during the start of the air conditioning season. Some
compressors just have a hard time starting after sitting all winter long. Some
compressors are locked up so bad that I can not start them and must tell my
customer that they need a new compressor . Many
times I can get the compressor started again without having to buy a new
compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They
have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
could be caused by a bad motor run capacitor. If
compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They
have saved many of my customers from having to buy new air conditioning systems
compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They
have saved many of my customers from having to buy new air conditioning systems.
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
