Question about Husqvarna Garden
Husqvarna yth2348 was cutting grass it sputtered died and now wont start just clicks
  • Husqvarna Master
  • 1,169 Answers
It may also have a partially short PTO clutch drawing so much power that the alternator can not supply enough power so it drains the battery until the fuel shut off solenoid kills the engine.
These PTO normally draws 5-7 amps with a resistance of about 1.7 ohms. Anything under 1.5 ohms indicates a shorted condition. I had a couple clutches that was still working but was pulling 18+ amps.
Posted on Apr 30, 2015
    Top Expert:
  • Husqvarna Master
  • 42,034 Answers
Check battery connections are clean and tight
check battery condition
check all wires and terminals.
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 11 Answers
SOURCE: Problem with the Husqvarna Lawn
http://weborder.husqvarna.com/order_static/doc/usa/2009/I09000/I0902011.pdf
Posted on Sep 06, 2010
  • 3911 Answers
SOURCE: Husqvarna YTH2348 - blades wont engage,everything
there is an electric clutch, also called a PTO, which is on the lower end of the motor's drive shaft. If you look underneath the mower in the front you will see it, a belt is on it which goes to the deck and spins the blades. The PTO has an inline fuse which could have blown, unfortunately it is generally caked in old cut grass, spilled oil, and belt wear residue. You are going to have to get some light down there and take a long look at the PTO, find the wire coming from it, and follow it until you feel a bump in the wire, like a cat being digested inside a snake. Clean the bump well and you will see that it is really an in line fuse holder and you can take it apart and replace the fuse if it is bad. Having said that, when a fuse goes, it goes for a reason and that is generally the PTO is failing and shorting or drawing way too much current. The fuse is a safety valve. But it may get you through the cutting and you can call a mower repair shop and have them replace the PTO.
Posted on Jul 07, 2011
GM Elec
  • 1000 Answers
SOURCE: My 2 year old Husqvarna riding mower, with the
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
Posted on Sep 06, 2011
SOURCE: Husqvarna YTH2348 engine stall issue
Mine was doing the same thing. Just loosen the gas cap. If its on too tight the engine will stall because the air cant get into the fuel cell to replace the abscent fuel.
Posted on Sep 30, 2011
After 45 minutes of run time drops to half power
it is droping to half power to stop the motor from over heating check the water level and oil top them up.
Jun 27, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
WHY IS CUT UN EVEN? MOWER LEAVES LINES IN LAWN
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
2. Level the deck following the instructions in the manual
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a yardman 46 in cut riding mower, it is leaving grass in the middle. I have put new blades, change the belts, put on a new tention spring, so what is my problem?
Well one of the spindle assemblies, could be running a little slower on one side then the other. But I would take a guess that you are trying to cut grass, way too fast for the mower. Try running a ground speed a liitle slower and see what happens.
Good Day.
Oct 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 engine stall issue 23hp B&S. Full charge on the battery 12.7vdc. New fuel filter. 13.5 - 14vdc at full throttle. Cranked right up cut grass 20 minutes +/- begins to sputter as if...
Sep 26, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Sep 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My Husqvarna lawn tractor started smoking terrible about half way through cutting the grass today. Oil dripped out of the muffler. What is that a sign of? Have I blown the engine? I check tires and oil...
You mean Briggs and Stratton. Sounds potentially expensive. Call a local small engine repair shop. They'll tell you how much it will cost. A new engine might be $1k. Repairs a few hundred.
May 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
106 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
