The front panel is flashing clean and continues to do so even when I press start. The cycle will not start now.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door or lid lock also check pump for blockage
Posted on Apr 30, 2015
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
My kenmore dishwasher 665.17052400 clean light is flashing 7 times. I cannot locate the tech sheet to find out what is wrong. I have reset the panel and it will run then blink again after 15 mins or so. ...
Reset the Control Panel
A power surge or outage may cause the "Clean" light to flash continuously after power is restored. Pressing the buttons on the panel in order and within 5 seconds resets the control panel and turns off the flashing light. The buttons must be pressed in the following order: "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash." After pressing the buttons, your Kenmore dishwasher will begin a short, 12 minute test cycle and reset the control panel.
Door Switch
A broken door switch can keep a Kenmore dishwasher from operating correctly, resulting in a flashing "Clean" light. Testing the door switch requires removing the door panel to access the control panel holding the switch in place. A continuity tester can determine if the switch has failed once you remove it from the door. Replace the switch if it fails to pass the continuity test. Make sure to disconnect the electricity to the dishwasher before accessing the switch.
I hope this helps.
Jan 10, 2018 | Kenmore Dishwashers
Dell photo 966 streaked copies
Turn off the printer and open its front cover.
Press and hold the "Continue" button. While holding it down, turn the printer on. The power LED light will now start flashing. Once it stops flashing, release the "Continue" button and close the front cover.
Press the "Cancel" button four times in a row.
Press and hold the "Continue" button. The front panel lights will now start flashing. When they stop, release the button.
Turn the printer off and then turn it on again
Mercedes Custom Parts
Jun 06, 2012 | Dell Photo 966 All In One Print Copy Fax
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
Machine flashing F- gets stuck in cycle
press pause/ cancel twice to cancel cycle
select drain and spin if there is water in the washer.
re-select cycle and press start.
Hope this helps.
Sep 05, 2009 | Kenmore Elite 45986 Front Load Washer
My toner light is on but not flashing and error light is on.
Try opening the front cartridge panel, and, with the panel open, press the cancel button until all the lights start cycling up and down. While this is happening, close the front panel, then press the continue button. This should reset the error lights and you should be ready to print.
Feb 24, 2009 | Dell 1710n Laser Printer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
