Question about Vacuums
Need instructions on how to replace the belt in the vacuum cleaner head
I have the belt but can not figure out how to get the bottom off to instasll it
  • Mike Tellegen Apr 30, 2015
    Hi fern levin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Vacuums Master
  • 932 Answers
Fern,
We need to know what brand of vacuum you have so that we can help you better.
Posted on Apr 30, 2015
I bought a replacement brushroll because the one in the vaccum cleaner is worn out.How do I go about putting the brush in the vaccum cleaner. Do I pull it out or do I have to unscrew the entire bottom...
Greetings from GoVacuum,
Make sure the vacuum is NOT plugged in. In order to replace the roller brush, you'll need to unscrew the 6 screws on the bottom plate of the vacuum cleaner. Oreck uses a Phillips Head screw, so you'll need to get a Phillips head screw driver to replace the brush.
After removing the screws from the bottom plate, simply pull up on the plate by putting your fingers into the open area where the existing brush is located. After the bottom plate has been removed you will have access to the roller brush and belt.
You can now just grab the roller brush and pull straight up on it. It's beneficial to change the belt of the vacuum when you're replacing the roller brush anyways. There is a spare belt on the actual bottom plate of all Oreck XL vacuums.
You'll notice that the new roller brush has two black square plastic caps on both sides of the roller brush. You can look on the outside of this black cap, and you'll see the words OLD and NEW. Rotate the NEW side so it's facing upwards, and the OLD side is the side that's down inside the vacuum cleaner, make sure that both sides have the NEW side facing upwards. You'll need to wrap the belt around the silver pin in the back of the vacuum on one side, and through the roller brush's metal pulley on the other side. The just stretch the belt with the brush inside of it, and place the black plastic parts back into the vacuum cleaner.
Congratulations, you've now just replaced the roller brush in your Oreck!
Please feel free to email me if you have any questions on how to complete this repair, or just request a clarification through this Fixya page. My email address is chris.jones@govacuum.com.
If this repair solution was helpful, please be sure to rate this repair as helpful by clicking the 4 Thumbs Up icons in the top right hand corner of this repair solution.
Be sure to check out http://www.govacuum.com for all Oreck vacuum cleaner parts and supplies!
Chris Jones
GoVacuum.com
Mar 16, 2010 | Oreck XL2000 Bagged Upright Vacuum
Changing Belt on Riccar 8650
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris J.
Feb 17, 2009 | Riccar 8650/8625 s Vacuum
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
Instructions on changing a belt on an Elite Hoover Vacuum Cleaner Model # v5075-930 Serial # 089500053577
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=825812
Generic problem for all Vacuums
Posted by ed_maxwell on Jul 24, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 24, 2008 | Vacuums
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Kirby Heritage 84
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=699518
Kirby Heritage 84
Posted by sixbrocks on Jun 23, 2008
I can't figure out how to get the belt engaged on my Kirby Heritage 84. There are very simple instructions on the front assembly; however, the belt doesn't engage with the rotor, and the beater bar does not spin. When I have the front twisting section on the "Belt On" setting, it seems as though it actually disengages the belt. I see no faults in any of the mechanical parts, but just can't get the belt to go on the rotor.
(I purchased this machine @ a garage sale on Saturday. It's in perfect condition.)
My vacuum cleaner is a Kirby 84 Legend.
Help! Jennifer
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check your owner’s manual but the Kirby has a dial on the front of the machine and you needs to dial the belt off of the fan pulley counter clock wise and to check to see if the Kirby bell housing will release @ the top so that you can remove the bell housing. If not then remove the bottom plate and take out the brushroll on one side and then slide the belt off of the brushroll. Then you can slide the new belt onto the brushroll to the center and then re-insert the Kirby brushroll with the screw heads facing downward then you can replace the bottom plate – then use the Kirby spoon or hook to dial the belt onto the fan pulley clock wise. Once that is done then plug in the Kirby and try to vacuum to see if the Kirby is picking up properly, if not repeat the process. If you have a question, feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Go Ahead. Use Us.
Jun 23, 2008 | Kirby Heritage II Vacuum
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566792
posted by Deb in Iowa on May 03, 2008
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the instructions still available? Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I believe so, but you would have to contact the Hoover Factory and they would have to send out either the owner’s manual or a copy of the owner’s manual from the fische. I remember this vacuum cleaner well. In order to change the belt you need to remove the 4 screws in the bottom of the power nozzle and then the top cover will lift off from the back to the front and then you can get in to change the belt. Always use the Factory Genuine belts instead of the replacement belts, they last longer and the average belt change for a flat belt is every 4 to 6 months as a rule for the best cleaning. In order to change the belt, lift up the pulley side of the brushroll and slide off the old belt and then slide on the new belt and re-install the brushroll, then use a belt puller or screwdriver with a hook on the end and to pull or stretch the belt onto the motor pulley, once you have it on the vacuum track the belt in a straight line and then reinstall the top cover and screws in reverse. If you have questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 03, 2008 | Vacuums
1800 vacuum cleaner belt replacement
How do you get into the belt to replace it?
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
http://www.dooyoo.co.uk/vacuum-cleaner/typhoon-1800-upright-vacuum-cleaner/1021772/
Apr 07, 2008 | Vacuums
Belt is broken
Most upright vacuums will have 2 screws on the bottom of the vacuum. Remove both screws and snap off bottom cover to get inside of the head. Remove old / broken belt and slide agitator off from the head unit. Stretch new belt with both hands then place around the agitator and pulley coming out of the motor. Place the agitator back into place (there will be some resistance from the new belt, but that is common). Put back on the bottom cover and place back the screws. You should be all set then. Hopefully this helps.
Mar 14, 2008 | Fantom Vacums CW600 Upright Vacuum
Hoover u5227-930 Elite Upright
I figured it out! The key is removing the "head" that covers the headlight - use a flathead screwdriver to pop it off.....then the belt connects from the agitator to the motor pulley. Phew!
Jan 20, 2008 | Hoover U5227-930 Elite Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
