Question about Hipstreet Flare 2 9 inch Tablet with 8GB Memory 2nd Generation and Portfolio Case
How can i reboot - Hipstreet Flare 2 9 inch Tablet with 8GB Memory 2nd Generation and Portfolio Case
Prestige elite 8 tablet was frozen now have a screen asking what to do, reboot system, wipe data/ factory reset, etc, what do I do?
if you reboot you lose no information , use the volume button to click down to reboot the press the power button .
Dec 28, 2015 | Tablets & eReaders
HOW TO REBOOT A SAMSUNG TABLET?
keep the on/of switch pressed for about 3 seconds, there will be three lines showing # power off # reboot # airplane mode. press the reboot and wait, action completed
Mar 02, 2015 | Samsung Galaxy Tab 3 7.0" - White...
HOW DO I UNDER FREZZER MY KINDLE
Hold the power switch for 20 seconds. Slide the power switch and hold it in place for 20 to 30 seconds before releasing it.
  • You need to physically hold the power switch in its off position for this long. Doing so tells your device to "reboot," in essence, instead of merely shutting down.
  • The reboot screen should appear as soon as you release the power switch.
Give the Kindle time to reboot. The Kindle will reboot within a minute or two. Be patient and give your device ample time to finish its reset.
  • There is some possibility that the Kindle will freeze as it reboots. This may be the case if your Kindle stays frozen on the reboot screen for more than ten minutes.
Charge the Kindle. If the device freezes during the reboot or does not respond to the reset at all, plug the charger in and allow your Kindle to charge for 30 minutes or more.
  • Make sure that your Kindle has enough time to complete a full charge.
Hold the power switch down again. After you finish charging the Kindle, slide the power switch and hold it down for another 20 seconds.
  • The reboot screen should appear again. Give the device a minute or two to reboot before checking it again. This should complete the reset.
Jan 01, 2015 | Amazon Kindle 3G
Kindle hd stuck on reboot
Try a hard reboot:
To reset/reboot your Kindle Fire:
-With the Fire charged but unplugged from the charger, press and hold the power button for a full 20 seconds.
-When the Fire cycles off completely, press the power button once to turn it back on.
Nov 22, 2013 | Tablets & eReaders
Tablet xhut off when on it
samsung galaxy 10 2.1 keeps rebooting and rebooting automatically. Displays going into power saving mode and reboots. stays on for aobut 10 seconds and then shuts down. Will not take a hard reboot. Help
Oct 29, 2013 | Samsung Galaxy 10 inch Tablet Wifi...
Wont reboot like standard reboots
If the iPad will not reboot using the standard "Hard Reboot" (holding the power button and home button until the iPad restarts.) then I would advise restoring the iPad using iTunes which will set it back to factory settings.
Jan 09, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Ipad2 not rebooting
If it can not reboot, you should bring it back to the Apple store for help.
Or call the Apple service center.
electronics wholesale
Nov 13, 2011 | Apple iPad 2 Wifi 16GB
Hipstreet Flare 2 9 inch Tablet with 8GB Memory 2nd Generation and Portfolio Case Logo
61 people viewed this question
Top Hipstreet Tablets & eReaders Experts
Lawrence Oravetz
ray gallant
Are you a Hipstreet Tablet and eReader Expert? Answer questions, earn points and help others
