Question about Whirlpool Dryers
I need a diagram of dryer drum belt placement on whirlpool model number wed8600yw0
Contact Whrilpool or perform an Internet search using Google or Yahoo. We don't have any user manuals or diagrams here.
Posted on May 11, 2015
Threading the dryer belt on my stackable frigidaire model. i need a diagram please.pulleys,tensioner and drum it is not getting tight. just need a pic.
A model number would have helped me help you a lot quicker. It took a lot of time just to try and guess here.
Yours will be one of these 2 diagrams:
westing.gif for 1995 and newer models ^--NOTE Belt ribs away from the drum on this one: frank.gif 1985-1995 models ^-Note: Belt ribs face drum on this one Thanks for choosing FixYa, Kelly
Aug 17, 2011 | Dryers
Tip
Whirlpool Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For models with non-removable back panels use this diagram:
Style: Flat with ribs
Installation Tips: Ribs against drum
For models with removable back panels use this diagram:
on Mar 06, 2010 | Dryers
Have a Whirlpool electric dryer, got it used, drum wasn't turning. Disassembled the dryer, removed the drum .... the belt pulley assembly was detached, and I don't know where it is supposed to go....
watch this youtube video it will show you at the 1minute23 second mark the exact placement of the idler pulley in the base frame and also how the belt fits on the idler and motor pulleys pause at 1:23 to see where they go http://youtu.be/CFnXwmUb4f4
Good luck
i hope this helps and if it does please give me 4 thumbs up
Gene
Jul 29, 2011 | Dryers
Installing belt around drum
There are several helpful dryer belt diagrams that are available at repairclinic.com. Just go to the site and click on "Get Repair Help". Under Large Appliances, select "Dryers". Look for the "Click Here for a Belt Installation Diagram" link. Refer to either diagrams H or K. If you are confused on which diagram applies to your dryer, please post back with your MODEL NUMBER so I can assist you further. I hope this helps you.
Dec 18, 2010 | Whirlpool Dryers
The pulley and brcket fell off it's position laying in the bottom of the dryer don't know how it goes ?
If you are referring to the tension pulley that keeps the belt tight on the drum, just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belts. A replacement pulley can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number is 691366 (if needed).
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 13, 2010 | Whirlpool Dryers
What is the routing of a dryer belt? It's a Roper dryer model GL6050VLO
To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
You can also refer to pcappliancerepair.com for some excellent exploded view diagrams of your dryer. Just type in your model number as "GL6050VL0" (the last digit is a zero, not the letter O), and go to the "Bulkhead" section.
NOTE: Roper is manufactured by Whirlpool, so these instructions will apply.
If you have questions, or require additional assistance please let me know. I hope you find this information helpful.
Oct 17, 2009 | Dryers
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
Dryer drum will not turn
The problem could be a faulty motor or a displaced drum belt or an internal wiring problem.Calling the tech would be preferred.But in case you want to locate the problem by yourself, post the model number here and I can help you out with few internal diagrams.Good luck,Please do rate my answer and post comments.
Jan 17, 2009 | Whirlpool Dryers
Parts diagram
Request the diagrams you need directly from Whirlpool
Oct 09, 2017 | Whirlpool GGW9250PL Gas Dryer
Dryers Logo
93 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
