Question about JVC Televison & Video
My jvc AV-29QT19 was dead but relay clicks - JVC Televison & Video
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: dead jvc tv,av-27320
There is most likely the main power supply has several shorted parts in it, depending on how old it is, it might be worth at least an estimate. if you have homeowners insurance, you may want to concider reporting this to them. Good Luck
Posted on Apr 06, 2007
micromend
  • 748 Answers
SOURCE: AV-27BM5 relays click on but no picture,high voltage or sound
It's been my experience that symptoms that point to the power supply, generally are not the case. Schematics now days are tough to find unless you are an authorized servicer for that brand. There are a couple of generic dealers out there but they don't carry everything. Before you replace the power supply I would suggest you go though other boards first looking for bad solder connections and/or transistors and IC's that may be defective. A good DVM with an ohm's scale should suffice. If you still can't find anything, I would suggest taking it to a reputable repair person.
Posted on Feb 25, 2010
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
JVC model AV-27750 does not power up
Could be power supply failure
Jun 30, 2017 | JVC AV-27750 27" TV
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
TV 65'' JVC AV-65WP74
Defective power supply
Aug 14, 2017 | JVC Televison & Video
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
JVC not turning on
Power supply is dead. It may have been damaged due to other failures.
You can send the set for a repair estimate. But, personaly I would be shopping for a new set.
Jerry G.
Mar 17, 2008 | JVC AV-27D302 27" TV
Dead jvc tv,av-27320
Apr 06, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
