1983 Jaguar 5.3l V12HE
I am having problems with the fuel supply, i have changed the fuel pump and the fuel is now reaching the spray bar but the injectors are not opening?
I sent the fuel Ecu unit away to be checked but they found no problems with it.
The injector are still not working/opening any ideas?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Sound electrical, go over the electrical components again.
Posted on Aug 24, 2009
  • 2 more comments
  • Phredus
    Phredus Aug 26, 2009
    Check the pressure before it reaches the injector. Then check that the injectors ar in fact opening and closing when you apply the electrical current .
    ­A fuel injector is nothing but an electronically controlled valve. It is supplied with ­pressurized fuel by the fuel pump in your car, and it is capable of opening and closing many times per second.
  • Phredus
  • Phredus
  • Phredus
    Night Owl:
  • 105 Answers
Check your fuel regulator, sounds like not enough pressure is present to open the injectors.
Posted on Nov 21, 2007
Have a 2001 jaguar vanden plas. It won't start. It cranks fine battery is good but it won't turn over. I have been told could be fuel filter and or fuel pump. If you agree how do i change
To confirm that is is the fuel pump at issue here get a can of spray starting fluid and next time it won't fire up spray it into the air intake hose of the engine while someone cranks the engine over, if it lights right off then the pump may be the problem. A clogged fuel filter may cause loss of power but seldom if ever a no start.
Feb 15, 2012 | 2001 Jaguar Vanden Plas
I have a 1983 Jaguar Vanden Plas XJ-6 Fuel Injected.Car will start when primed and run,But not on its own. I have replaced fuel regulator. I need help to trouble shoot.
Hi,it certainly sounds like a fuse for the fuel pump ,or its the fuel pump itself ,the only other thing i would check is the fuel filter that may be blocked ,it will be 1 of the above ,i would check the fuse 1st ,then the filter 2nd ,and pull off the fuel line connected to the filter and have someone turn the key to start and access wether you have fuel pumping out ,it should squirt out violently if the fuel pumps working properly.Please point the fuel hose into a bottle while doing this test to minimise fire danger .THANK YOU for using FixYa
May 08, 2011 | 1985 Jaguar XJ6
I keep having a problem with my fuel injectors, i now cannot get fuel through having cleaned them. help.
IF YOU FILLED FUEL TANK.POUR CAN OF SEAFOAM OR DIFFERENT INJECTOR CLEANER IN FUEL TANK. AND INJECTORS STILL NOT SPRAYING FUEL. CHECK TO MAKE SURE FUEL PUMP RUNNING.HAVE VECHICLE HOOK TO SCANNER BECAUSE YOUR PCM CONTROL FUEL PUMP AND FUEL PRESSURE TO FUEL INJECTORS.LOOK A FAULT CODE FOR FUEL PUMP OR PCM.JAGUAR IS TYPE CAR YOU NEED DIAGNOSTIC EQUIPMENT TO TROUBLE SHOOT THEM.IF YOU TOOK FUEL INJECTORS OUT CLEANING THEM BY HAND YOU COULD HAVE FORGOT TO RECONNECT WIRE CONNECTORS OR YOU COULD HAVE STOPPED THEM UP COMPLETELY.
Oct 04, 2010 | 2006 Jaguar X-Type
Jaguar 1983 injector no pulse
might be wise to check the fuel pressure
Dec 04, 2009 | 1983 Jaguar XJ
I have a 1990 xj6 jaguar. Two problems I am
Had a similar problem within the last year. Either your fuel pump is failing or your fuel filter is partially blocked. Change both and drive away.
Jul 30, 2009 | 1990 Jaguar XJ6
1992 Jaguar
change fuel filter first. confirm fuel pressure at rail.
Be sure there are no pinholes in your return lines.
Jul 15, 2009 | 1992 Jaguar XJ6
1983 bmw 320i
I have the same problem, I just haven't gotten around to fixing it - Theres three very typical causes, the cold start valve, thermo time switch, or fuel pump. Check your Thermo Time switch, located on the top front of the engine, it a temp sensor that tells the engine computer how much fuel to use for things like cold starts, if its bad it can in theory cause the problem we're having, it will cause rich running when it does finally start, and lean running on start up (not enough fuel, which explains for me why it starts promptly and dies a second or 2 later, the cold start valve is the only thing helping it get enough fuel). The part typically costs around $90 (thermo time switch). The thermo time switch should have between 2000 and 3000 Ohms of resistance between its terminals at 68 degrees F. Check it when its very near that temp. Also, you may wish to do a "leakdown" test, which involves testing the fuel pressure near the fuel pump. The "i" models have 2 fuel pumps, one in the tank (primary) and one outside the tank (secondary). The primary supplies low pressure to the secondary, and the secondary supplies high pressure to the engine. Off the top of my head i cant tell you what the pressures should be, you'll need a haynes manual or the Bosch Fuel Injection manual to know for sure. But if it does drop sharply after start up, you either have a leaky Cold Start Valve or a bad fuel pump. You can also check the Cold Start Valve by pulling it off and putting it in a glass jar (lines attached), and just "start" the engine, watch to see if its spraying. If it is functioning properly it will only spray when the key is in the start position. If it doesnt spray at all, its probably bad. If it leaks when the key is in the "on" position, then it is bad.
Hope that helps
Feb 01, 2009 | 1983 BMW 3 Series
1983 van has been sitting awhile, can't get ga sto carb
Pump the gas while looking down into the carb, if you see a spray of fuel then there is gas in the carb bowl. and the pump is working, if no gently tap on the carb fuel bowl, the inlet valve may be stuck closed from varnish caused by dried fuel.
Oct 16, 2008 | 1983 Ford Econoline
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
