Question about Invacare Pronto M51 Power Wheelchair
Just installed new batteries but the charge doesn't last as long as it used to.
When I first got the chair, it would go all day but it started losing charge earlier so I change batteries but still not lasting as long as before.
skaterkid307
  • 86 Answers
SOURCE: Jet 3 will not charge.
you need to go to the store u bought it at and ask them
Posted on Feb 20, 2010
  • 4044 Answers
SOURCE: last month I replaced the
This is usually a sign of a dead cell in the battery pack but since this is a sealed unit and most likely a NikAd unit you won't be able to repair that. On the other hand, if there is a loose connection inside the motor or the motor is going out and pulling more power than normal you will get this condition. You have a couple of options. Option 1 is to open the motor up and clean it out of the build up and re lubricate it properly. Dust build up and gunk, for lack of a better term, could be hindering the motors operation. Option 2 would be to replace the motor itself. I have never opened one of these but I have seen them and there is nothing easy about it but it would be cheaper to open it and repair and clean the inside than to replace it totally. If that fails then you are left with replacing the motor. This all assumes the battery you installed was a new battery and not refurbished and doesn't have a bad or weak cell in it causing the problem. The battery is always the first place you look when you have this problem. Your power available gauge is operated by testing the available Volts unfortunately the Motor requires Amperage. You can have volts available but if there is a bad cell there won't be sufficient Amperage.
Posted on Oct 31, 2010
  • 692 Answers
SOURCE: my pronto power chair m71 standard the battery
anne no It means you need new batteries. If Medicare paid for your chair then they will pay for 80% of the repair costs. Contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-80467-2668 and they will send a tech out to check it for you and bill Medicare Hope this helps
Posted on Feb 22, 2011
  • 346 Answers
Morning,its people like yourself that i am here.Please visit:www.alldatasheet.com
SOURCE: Why will charge in chair only last short time ? I have already installed new batteries and replaced charger
Does your chair turn off automatically in about 10 minutes. Sometimes customers make the request to the tech to set the chair to never turn off because it is an inconvenience to have to turn it back on. As you have experienced, its a much greater inconvenience to have a dead battery. There are also longer settings up to 1 hr. The batteries may be fine, you are just running them down because the chair is on when not in use. If this is the case, you need to contact a tech who has a programmer that can change this setting. I had one customer that had a similar issue as yours but also had performance issues. Riding on a flat surface the chair would do fine, but when he would start to go up an incline, the battery level would start to drop as the motor would torque. I found that he had a bare wire rubbing against the frame and it would not affect the performance until it required more power from the batteries. Look at all the wiring if you are able and see if it is intact. The worst case may be that you have a bad wire that has a break in it and will do the same thing as the bare wire scenario. One more thing you can look at is the battery connections. If they are loose, you will see alot of problems. Bad charge, low performance, wont climb inclines. Everything has to be tight and in good condition to get the best performance. Check all connectors. I have seen melted connectors do the same thing. If you have any melted components, get the unit serviced. You don't want a fire under your seat.
Posted on Jan 29, 2015
We have a pride jazzy 1143 select power chair. we have had problems with the batteries going bad. I purchased a new set of batteries last December. in June they would not hold a charge and I purchased a...
charger is no good or is not the correct charger for that chair suggestion have a dealer tech replace a original charger in chair,it should have a 3 yr warranty anyways
Oct 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
My chair has been sitting for 4 months in garage. Chair MPV5 was rarely used. When charging, battery charger indicator shows green light. Chair still does not turn on. What should I be doing?
Replace the batteries and charge before use then charge nightly for 20 days Use the chair daily so you can get a good charge nightly to get the batteries operating at 100% After the 20 days If you don't use the chair daily always store fully charged and then charge once a week overnight. Should work fine once you get the new batteries in You will need to get 2 U1 batteries for your chair do not get Wally World or automotive batteries You must replace with sealed deep cycle batteries made for power chairs Hope this helps
May 07, 2011 | NRS Hoveround MPV 5 - Used Power...
Unit charges shows full and by mid day in a nursing home battery lights show only 2 red lights. do i need to replace batteries. the chair is a jet3 it was bought in 2003 and not used for about 2...
You definitely need new batteries. There are 2 size U-1 batteries in the chair that will last between 1.5 and 2 years. Get the deep cycle sealed gel lead acid batteries, preferably AGM. Hope this helps.
Feb 15, 2011 | Jet 3 Ultra Power Chair
Batt. were left uncharged for a year. how do I recharge them. they don,t charge with the charger on the wheelchair.
You can't recharge them. they are dead and if you could they wouldn't last. You will have to spring for 2 new batteries. Check with an Interstate battery outlet and purchase 2 U1 sealed batteries for your chair charge before use and charge daily for 20 days to break them in. If you don't use the chair daily charge at least once a week Hope this helps
Jan 27, 2011 | Jet 3 Ultra Power Chair
Chair was charged last night and now the power light flashes and chair will not move
NEW BATTERIES NEEDED TRY CHARGING CONSTANT FOR 16 HOUR IF POSS OR OVER NIGHT. IF BATTS KEEP FAILING THEN SERCH NEW BATTERIES ON THE WEB A PLACE IN WALES DO THEM NEXT DAY DELIVERY GOOD VALUE
Dec 24, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Hello, After fully charging my mother's Jazzy power chair overnight, the rear battery indicator/pointer shows zero meaning it's fully charged. I leave it unplugged all day and then by 5pm when I check...
Sorry but it sounds like weak batteries. I would replace both batteries and after installation fully charge before use. Then ask Mom to use the chair more each day so you can charge them overnight each day for the next 20 days. It will break in the batteries and get them operating at 100%. If you can get her to use it more and charge it overnite and always put it up at full charge the batteries should last 2-3 years Hope this helps
Dec 16, 2010 | Jet 7 Portable Power Chair
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
A few months ago, I got 2 new batteries for my Jazzy and the first month everything was fine. Lately the batteries have been losing power abnormally fast. We were told to keep the chair plugged in at all...
Jeff WRONG!!!!!! I would demand that the dealer give you new batteries (they should be under a six month warranty anyway) You are to NEVER repeat NEVER leave the charger or chair plugged in all the time. The most you should ever have to charge the batteries is overnite or 12 hours. Never leave the charger plugged into the chair more than 24 hours. Doing so might even void the warranty. Tell that dealer or however told you that to take a hike or at least know what they are talking about. Have them read an owners manual (if they can read) under care and use of batteries Geez it just upsets me to have people give out such bad information to their customers. Now the batteries need to be replaced and when you get new ones charge them before you use the chair then charge then everynight if you use the chair daily if you don't use it daily make sure it is fully charged when you put it up and at least once week (if idle that long). I would recommend using your chair daily for a little while to run the batteries down some and then charging overnite for the first 20 days that you have the new batteries this will break them in. Hope this helps and sorry for the rant
Sep 25, 2010 | Jet Health & Beauty
Invacare Pronto M51 Power Wheelchair Logo
152 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
