Question about Huawei Cell Phones
How can I remove the battery from Huawei phone?
My huawei phone fell into water. What shoukd I do to get it working again?
DO NOT TRY TO TURN IT ON!!!
Remove the battery. Let them both dry completely. If you have some, put the phone in a bowl of uncooked rice for a day or two.
Once the phone and battery are completely dry, put the battery back in and try to turn it on. If it comes on, you're good to go. If it doesn't come on, then it's time to go shopping for a new phone.
Oct 10, 2016 | Huawei Cell Phones
Ascend y330. Where can I get free SIM unlock code?
http://sim-unlock.net/simlock/Huawei/Y330
How to unlock Huawei Y330 by code?
Unlocking Huawei Y330 by code is very easy, it is also safest and non-invasive method of unlocking your phone. To get code for unlock Huawei Y330. You need to provide IMEI number of your Huawei. Type on keyboard *#06# or remove battery from your Huawei Y330 to check IMEI number.
To unlock Huawei phones you need to provide them with IMEI number and model of your phone.
Huawei Unlocking process is safe and easy.
Nov 21, 2015 | Huawei Cell Phones
What should I do to my phone if it won't turn on after charging it overnight?
you need to reset your phone. can you tell me the model of your huawei phone?
May 21, 2015 | Huawei Ascend Y300 Mobile Phone
WEAR IS SIM CARD SLOT FOR HUAWEI M 835
1.Carefully push the SIM card out of the wallet-sized plastic card carrier.
2.Turn your Huawei M835 off.
3.Grasp the notch at the top of the back panel and pull away from the Huawei M835 to remove the back cover.
4.You'll see a notch at the top of the battery.Use it to lift the battery out of the Huawei M835.
5. Your SIM card has one corner missing.Slide the SIM card into the SIM slot so that the corners match.Ensure that the gold contacts are facing downwards.You will hear a click.
6. Reinstall the battery and back cover and then power up the Huawei M835
Apr 29, 2015 | Huawei Cell Phones
My huawei does not want to start always show the phones logo and go of
Check the sim card. Remove it and refit it. Make sure it is fully in. Also check the battery contacts are clean. How old is the battery, it could be coming to the end of its life.
Feb 04, 2015 | Huawei Cell Phones
How do I do a factory reset on a huawei h868c when I cant get into settings
Huawei H868C Tutorials
there no a factory reset, try hard reset with phone on remove battery and install after few minuts
Dec 20, 2014 | Cell Phones
I lost my pin for t.mobile huawei g6620
Have you lost your sim network unlock pin ? If so, you can re-buy unlock pin from any of the providers like SuperUnlockCodes.com who helps to remove carrier lock from mobile phones in online to unlock your Huawei G6620 from network lock .
Dec 09, 2014 | Huawei G6620 T1201 T1209 G7210 T-Mobile...
M865 muve white cell phone cricket cdma water damage
If possible, remove battery. Place in a large bag of rice for at least three days. The rice absorbs any moisture. en reinsert battery and try phone.
Dec 29, 2012 | Huawei Ascend Ii M865 Muve White Cell...
I reset my huawei u8180 android and now it wont stay on
remove the back cover of your phone and the battery and try to open it again ^^,
Nov 27, 2012 | Android Huawei
How to remove battery from huawei m835
To remove battery from Huawei m835,
Turn the back of the phone, remove the outer covering(casing),
put your hand in the space provided to lift the battery and the battery is out.
Sep 14, 2011 | Cell Phones
Cell Phones Logo
32 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
