Question about Compaq Computers & Internet
Where can I find schematic diagram for hipro HP-D2537F3R?
Dont on power supply
power supplies are universal for PC's but based on wattage. Buy any power supply of that wattage or larger to replace the old defective one.
Oct 28, 2013 | Hipro HP-D2537F3R Replacement Power Supply...
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
How will i get free schematic diagrams for laptops
you will get most schematic on this site www.lqv77.com
Nov 03, 2010 | HP Pavilion dv6000z Notebook
Can you advise me of a suitable replacement for my psu which as stopped working. The psu fitted is fsp400-60mdn which i cannot locate a new one.Any advice would be very helpful Phil.
Unless this is a proprietary power supply design (special type case, custom-made equipment, oddball power connectors, etc.) you should be able to use any ATX replacement power supply with a suitable output rating.
I'm guessing from the number you give that the one you have now is a 400-watt supply. You can put in a higher-rated one with no trouble. They're all very close in size and have standard mounting holes, and excess capacity won't hurt anything. In fact, since under-sizing the power supply is often why they go bad in the first place, putting in one with greater capacity is usually a good idea. There's very little difference in price for the higher power ones.
Most supplies will have enough connectors to work with your motherboard and drives. Just check the specifications to be sure. There are so many sources and supplies available that I won't try to recommend a particular brand. I've used many and they all seem to work just fine.
Good luck with the repair, and thanks for using Fixya!
Mar 27, 2010 | Computers & Internet
HAVE A HIPRO PSU PART NO. HP5187-4875
A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Nov 11, 2009 | HP Computers & Internet
I have a HIPRO HP-305 power supply. The green
the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
Jun 14, 2017 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Computers & Internet Logo
290 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
