Question about Nikon 28Ti 35mm SLR Camera
Nikon 28Ti problem with panoramic shutter.
It looks like part of my panoramic shutter (top left corner) is missing when I developed my photos. Could it be broken?
    Top Expert:
  • Nikon Master
  • 43,014 Answers
Most likely it could be broke .
Posted on Apr 30, 2015
I developed 3 rolls of film recently, shot with my Nikon N6006. It was my first time using this camera. The lower half of all my photos was blacked out, due to, what the developer said, my lower shutter...
When the shutter assembly fails all you can do is to set the camera to manual exposure, select the "B" shutter speed, and with the lens off and the back open, fire the shutter. In the B setting the shutter will remain open as long as you hold the shutter button, allowing you to see if there's an obvious obstruction.
If there's nothing obvious, then the shutter assembly must be replaced and as it's an uneconomical repair on that model your camera effectively becomes a spares donor.
You can get similar models very cheaply on auction websites or even for nothing at all on sites like FreeCycle and Freegle as they're effectively worthless, even in good working order.
Aug 31, 2011 | Nikon N6006 35mm SLR Camera
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
Error Message
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Sep 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Hightlight message on Nikon D80
Highlight is just the info mode, there are several info modes including Basic file info, Shooting Info and RGB histogram, just press the round controller in the up or down direction to change between them in playback mode. Highlight will flash black anywhere there is pure white in an image.
Try resetting the camera by pressing the 2 buttons with green dots (on top of the camera near the shutter release) holding them for a few seconds.
Mar 08, 2009 | Cameras
Problems taking pictures on nikon d1x
There may be something wrong with the camera. Make sure it is set to Single Exposure setting and not Multiples. There should be a control on the top left to change this. Look for an "S". this is what you want. If that doesnt help, you may need to get it repaired.
Mar 01, 2009 | Nikon D1X Digital Camera
Nikon fm10 35mm SLR developed pictures turn out white
That sounds like your shutter isn't opening. take the lens of and set the shutter speed to B this should keep the shutter open as long as the release is pushed down. advance one frame and hold down the shutter release while looking at the opening where the lens should be. If the shutter opens you will hear it and see the back plane where the film would sit to be exposed. I expect your shutter won't open.
Good luck
Rob
Dec 11, 2008 | Nikon FM10 35mm SLR Camera
Pictures print panaramic
Double check your camera as this model did have a panoramic version available and you had a lever on the side of the camera to select normal/panoramic.
If this is not the case you may have a problem with the shutter on your camera.
Check on the negative and if the exposed part runs is the lower third of the negative it is a shutter problem and needs to be looked at by a repair tech, if the exposed part of the neg is even and runs through the middle of the frame. I am pretty sure you have a panoramic camera and you would just need to switch it off
Nov 15, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
Panoramic pictures??
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
Sep 13, 2007 | Minolta Freedom Zoom 115 QD 35mm Point and...
Photography Logo
642 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
