Question about Garden
Just purchased used. looks like someone bypassed safety switch on brake lever, the engine will not stop with key off, need proper wiring diagram
  • Garden Master
  • 2,478 Answers
On what please
Posted on Apr 30, 2015
SOURCE: Ignition does not crank engine
If it is cranking over it should start. If you are just jumping the solenoid then you have a switch problem.If it is just plain not starting then you need a complete tuneup. It a process of elimination, you need air, gas, and a spark. Then it will run.donnyb60
Posted on Mar 23, 2009
  • 376 Answers
SOURCE: need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Posted on Jun 09, 2009
  • 138 Answers
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Posted on Aug 17, 2009
  • 496 Answers
SOURCE: I have a 1983 Murray riding mower, I need to know
With the model number, you can obtain a users manual. I viewed their sample and it included the wiring diagram... SWEET!
Here is the link for your manual:
http://www.outdoordistributors.com/Murray/Murraypartslists.html
Hope this helps... Good luck!
Posted on Sep 22, 2009
  • 13 Answers
SOURCE: ferris zero mower;eng.dies when releasing brake or control levers
Check seat SW.
Posted on Sep 29, 2009
Testimonial: "Thanks, I've had problems w/that sw. before,I'am going to run an ohms test on it. That tells me where to start."
I have a lawn tractor which accelerates on its own and the brake will not stop it-near miss last week-smashed into concrete wall to stop
Does the key stop the engine? sounds like the safety switches have been bypassed. If the engine runs while not sitting in the seat, the switches are bypassed.
May 29, 2016 | Mtd Garden
Starter on truck is not starting truck
There are safety switches on the brake pedal lever(automatic) or clutch pedal lever(stick) depending on year. What usually happens is that your feet bump or break the switch and you lose the starter pulse. This switch is suppose to prevent "runaway" vehicles by insuring that your foot is on the brake pedal or clutch when you use the starter. Look under the drivers dash on the brake or clutch lever.
There can also be another switch on some models that is for safety and insures the gearshift is in Park. Finally, some ignition switches have adjustments where they attach to the steering column. The ignition switch has slots which allow the adjustment.
The loss of your signal to the starter relay can be verified by using a Voltmeter on the small wire of the starter relay, then backtrace the above switches to restore the signal.
Diagrams are on the Web by doing a search specific for the year, make, and model followed by which part you want to find. (example -fusepanel or powerbox)
Oct 20, 2014 | 2011 Ford F-150 Regular
Why does engine stop, when I take foot off brake pedal?
1 safety switch under seat. 1 on deck engage lever. 1 on brake. It sounds like the brake switch is working. its most likely your seat switch that is bad or out of adjustment. you can try bypassing switch by unplugging it from wires and run a piece of wire between the 2 contacts on the plug with the wires. If that works you need a new seat switch.
Jul 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Key will not turn on engin on 2007 volvo
Check your Brakelights. Some cars have a safety lockout which prevents starting your engine without your foot being on the brakepedal. If the switch on the brake pedal lever has been moved or broken by the Drivers' feet, it may not release the Key to turn.
If you lack Brakelights, then someone needs to go under the dash and attend to the Brake pedal lever switch.
Please rate my info.
Nov 12, 2012 | Volvo Cars & Trucks
Every time I use the lever to get the blades started it kills the engine. it does it even after i removed the belt. what is causing the blade rotation lever to kill the engine?
hi there talane
sounds like you have a safety switch problem
try disconnecting seat switch and retry if works could be wire grounding some where or faulty switch then try fitting a jump wire to seat switch wire connector then retry then check blade engagement switch may be playing up or a nuetral switch playing up but more likely a seat switch
with operator off seat and park brake on engine runs, but with pk brake off and operator off seat
engine stops , same if operator leaves seat and blades engages -engine stops,
if unit not in nuetral and pk brake not on unit wont start
take look
hope it helps
cheers pauly46
Jul 03, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need the wire diagram to rewire my Ariens lawnmover to bypass the safety switch. It is Ariens GT-19 model # 931026 Serial # 001463. Can you help? It is an old Ariens mower but still runs good but now I...
here is owner manual:
http://apache.ariens.com/manuals/030305C.pdf
usually the switch is behind the ignition, sometimes at the N position of gearshift, just look for a switch with one wire coming in & one going out (usually the same color); disconnect the two wires & jumper them together to bypass the switch. Looks like yours has one under the seat.
Apr 25, 2017 | Sport & Outdoor - Others
Engine Stalls when put in Gear, Suzuki GSX-R 1000 K3 (2003)
Most of the safety systems use a diode pack in the loom to stop clutch and side stand switch etc from back feeding each other. Maybe this has failed. If not could it be in the loom, a broken or shorted wire. Look for a tight bend in the route the loom runs and external damage to the tape.
Aug 05, 2009 | 2003 Suzuki GSX-R 1000
I have a 2002 Isuzu Axiom 4 wheel drive. When I go to start it, it just clicks. If I jiggle the shifter, it will start. Also, the child protection on the door looks when first engaging the brakes has also...
if you can jiggle the shifter and it will start it sounds like your neutral safety switch. its located down there on the transmission or on the lever. you can bypass it by cutting the wires going into the switch and wiring them together. problem is it will start in gear then. the switch is either down on the transimission where the linkage goes into the tranny or in the console
Mar 20, 2009 | 2002 Isuzu Axiom
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
