Question about Frigidaire Refrigerators
Can not remove filter from frigidaire
Water filter will not come out. I am afraid to break something
  • Official Brand Answer
  • 2,267 Answers
Good Morning Tory, thank you for your inquiry!
I understand that you cannot remove the water filter from your Frigidaire refrigerator. It could be possible that your filter is frozen I would recommend performing a manual defrost on your refrigerator. You can do that by unplugging the power cord for at least three to four hours. I hope this information is helpful to you. -Matt
Posted on May 06, 2015
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: GE Fridge - The water filter bypass plug is stuck
Should just take a quarter turn CCW to remove. You may loose a few drips of water, but the water shuts off automatically when the plug or a filter is removed. A wrench should not be needed to do this.
Posted on Jul 26, 2010
Frigidaire water filter stuck
We had the same issue. My husband unscrewed the filter cover (1 screw on the left side of the filter under the light flap). Then he pushed the old filter in & lifted it up and it came right out.
Oct 02, 2012 | Frigidaire ULTRAWF Frigidaire PureSource...
Has anyone had any problems with a frigidare pure source one filter leaking water at a slow drip?
remove the filter, look inside to see if anything is misaligned. BE CAREFUL, these things break easily, then you must buy a new filter unit.
May 05, 2012 | Frigidaire Refrigerators
Recently, I noticed water on my refrigerator shelves. After looking into the issue, I noticed that the leak was coming from the water filter. I purchased and installed this filter 6 months ago and did not...
It sounds like the gasket is either broken or crimped in some way . you should find the valve under the sik shut it down and remove the filter and check gaskets for crimps or breaks . It could also be just lose as well
Jul 23, 2011 | Frigidaire PureSource2 Water Filter WF2CB
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
E20, slow to drain frigidaire atf7000fs
probably has something stuck in the electric drain pump happens alot on frigidaire washers it is accessable after removing front lower acess panel tilt washer back after pulling it from the wall the drain pump will be just right of center at the front use a pan to catch any water that will come out you can either remove the 2 drain hoses to clear obstruction or you can unscrew pump motor from pump body
Good Luck!!
Thanks.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire Pure Source 2 filter problem
replacement puresource 2 filter will not "snap" into place!
Jun 07, 2009 | Frigidaire Freezer Refrigeration White...
Fuel filter
There is a tool you can buy for just a few dollars that you need to use to get it off at any auto parts store. They usually come in a pack or multiple different sizes. After that, it should only take you a few minutes.
Sep 07, 2008 | 1997 Ford F150 Regular Cab
Water hose popped out form water dispenser outlet
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
Do you have the users manual?
In there will be a diagram showing you where the water filter is and tell you how to remove it to change filters!
If you do not understand it !!STOP and call service!
the number of a good nation wide service company is below
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Aug 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water in bottom of dish washer
you probably have something stopping the drain pump operating (like a tooth-pick or piece of plastic that won't break down in water) its a take it to pieces job i'm afraid but if you are fairly mechanically adept you can do it yourself. the drain pump is quite small and nearby to the drain outlet- you need to remove the case and release the drain from inside the unit- remove the pump itself and you'll prbably find somthing stuck in it- remove and re-assemble. In the meantime DO NOT use the dishwasher as you will 'burn out' the motor as the pump rotors are jammed.
Hope this helps
Feb 18, 2008 | Bosch 18 in. SRS43E02 Slim-Line Built-in...
Refrigerators Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
