Question about Coby Wireless Car FM Transmitter Electronics Corporation CA745 CA-745
It has stopped working. what fuse does it take and where is it located? thanks
No direction indicators hazard lights
try changing ur flasher unit also located on ur fuse box
May 02, 2014 | Hyundai Cars & Trucks
My sunroof has stopped working
Thanks for choosing FixYa. Do you know where your fuse box is located?
Jan 24, 2012 | 2006 Renault Clio 1.4
Why is my tail light, park light stop working at the same time?
you have a blown fuse for the running lights,consult your owners manual for a fuse location for tail light fuse location.then replace the fuse.your tail lights should be off when replacing the fuse.after you replace the fuse,turn the lights on to see if this repairs your problem.thank you for choosing fixya.com
Feb 27, 2011 | 2003 Honda Pilot
Central door lock system not working
CHECK THE DOOR LOCKS MAIN FUSE.
May 03, 2010 | 2000 Honda Accord
We have a 2005 GS 500F. The turn signals stopped
Try replacing the indicator relay, the fuse won't just go unless the circuit has been overloaded (unlikely if you haven't touched it) the relay will be somewhere by the headlight, as for the fuses they usually are located to the left or right below where your handle bars are (under the plastic cover/fairing)
Mar 26, 2010 | 2004 Suzuki GS 500 F
2002 Acura TL Type-S Radio Fuse Blown??
Passenger Side fuse box, fuse number 9 neets to be replaced
Dec 09, 2009 | 2005 Acura TL
Our wipers just stopped working. where is the fuse located?
yes there is a fuse located in the fuse box it should be listed under accessories either use a test light to figure out if it is bad or pull it and replace it with a new one
Nov 13, 2009 | 1986 Toyota Cressida
2004 Nissan Maxima wiper problem
Karen...
There might be a fuse with more than just the wipers on it. Does anything else not work? A blown fuse is most likely the cause, it might be hard to locate check owners manuel for fuse locations as they can be in several locations.
Denny
Jul 07, 2009 | 2004 Nissan Maxima
Which fuse controls the windshield wipers??
There is no separate fuse for intermittant. You have a wiper fuse, and that's all. If that part has stopped , you have a probel with the switch, or the circuit board for your wiper motor.
Jun 06, 2009 | 1998 Isuzu Amigo
Coby Wireless Car FM Transmitter Electronics Corporation CA745 CA-745 Logo
594 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
