Question about Amana Microwave Ovens
How do I replace the fuse in AMana Commercial RMS10D
  • Amana Master
  • 932 Answers
Val,
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Be very careful about touching electrical connections because there can still be some live current stored in the capacitor. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Posted on Apr 30, 2015
    Master:
  • 530 Answers
Open the cabinet
Amana RS10D Not heating up . Fuse,2 thermal cut out, door switch, all ok. board/ magnetron/ transformer dead? Pls help. Don't want to discard 5 units...all same problem...Thanks
I regularly repair Amana commercial microwave ovens.
  • What is the FCC ID number from the tag?
  • What is the Manufacturing number (like P76695, etc.)?
  • Is it making any unusual noises?
  • Is it running quieter or louder than usual?
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 11, 2017 | Amana Microwave Ovens
Amana microwave reset button?
Does the power panel have anything on it?? If not. it probably has a burnt fuse inside the unit, one year old should have a warranty on it Check out places that work on microwaves.
Mar 05, 2015 | Amana Commercial Microwave RMS10TS Touch...
Clean the filter on an anna microwave oven HDC18
The service manual (here) covers that.
You can order Amana parts from the Pros here.
Jan 15, 2013 | Amana Microwave Ovens Amana HDC18 - C-Max...
I want d manual of Amana Commercial Microwave Oven Rc17 1700 watts
You can download the manual from the manufacturer's web site at
http://www.kitchenaid.ca/assets/pdfs/literature/SK926001.PDF
May 27, 2011 | Amana RC17 Microwave Oven
Under the inside cover (right side) i see what appears to be burning when operating unit - is there something behind that removable cover that can be replaced or repaired to solve the...
Replace the cover as it is obviously dirty with carbonised food particles. Don't use it without a new Wave Guide Cover or permanent damage to the magnetron/aerial may result.
Dec 17, 2010 | Amana AMV1162 Microwave Oven
I have Amana Commercial microwave RFS12SW2 The fan keeps running even door is open , it wont stop.
These microwaves are designed to run the fan for a couple mins after the cook cycle to continue cooling the electrical components.
Oct 20, 2010 | Amana RFS12MPS Microwave Oven
Microwave went POP and stopped.
probably not the fuse. If it is, then something caused it to blow as a fuse is a safety device. Since microwaves can be dangerous due to the radio waves, here is what I've done in the past. I had Sears come out and diagnose the problem. Before tech left, I told him I don't have the money to fix it now but will do it in a month or two. I had him write down the parts I needed and the part numbers so when I do want it fixed, I do not have to start at ground zero. He was glad to help. I watched everything he did, and since I work on commercial microwaves, amana, it was no problem for me to order the parts and do the repairs myself. My microwave is a 1200 watt over my stove.
Keep in mind that microwaves are getting so cheap, that you may want to look into just what a replacement will cost.
Feb 05, 2009 | Jenn-Air JMC8100 Microwave Oven
Amana microwave RC17
There is a bulletin that shows how to reset this code on Amana commercial microwaves.
We have uploaded it to our site here to help you.
Oct 03, 2008 | Amana RC17 Microwave Oven
Possible fuse -- no power
Replacing a fuse Locate your fuse. Most microwave fuses look like the one pictured to the left. They are usually an inch or two long. Each end is metallic and the center is either ceramic or glass.
To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Decide if your fuse is blown. A blown glass fuse will produce flash burn marks on nearby surfaces, or it will be completely black on the inside. The internal fuse wire (filament) will be melted and blackened. Ceramic fuses give no outward signs of having blown. To determine if a ceramic fuse is blown, test it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is fine. A reading of infinite ohms means your fuse is blown.
Replace the blown fuse. Pop it out of its holder and snap in a new one. You can squeeze the fuse clips together with your fingers in order to tighten their grip. Replace the unit's outer cabinet, plug it back in, and test to see if it is running properly. DO NOT run the microwave with nothing in it.
NOTE: Fuses do not usually blow on their own. A fuse may blow because of problems with the interlock switches or with high voltage circuitry. It is also possible, though rare, that a power surge will cause a fuse to blow.
Jun 05, 2008 | Amana RCS 10D 1000 Watts Microwave Oven
Microwave Ovens Logo
136 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
