Question about Jeep 2001 Grand Cherokee Limited
WHAT DOES OIL PRESSURE GAUGE LOOK LIKE ON 2001 Jeep Grand Cherokee
    Master:
  • 530 Answers
It's a light
Posted on Apr 30, 2015
What is the correct oil pressure for 2000 grand jeep cherokee larado its about 75 now. i want to buy this car but worried about the oil pressure.
Normal oil pressure should be between 40 and 60 psi. A cold engine will normally have higher pressure. If you're seeing 75 psi on a warm engine I would recommend having the pressure checked with a manual gauge to verify the gauge in the Jeep is working correctly. If the gauge is correct oil viscosity may be too high (oil too thick) or there may be a problem with the oil pump pressure relief valve. If the gauge is not correct the sending unit may be at fault.
Apr 09, 2011 | 2000 Jeep Grand Cherokee
The oil pressure guage on my 2000 Jeep Grand Cherokee is registering 0. My oil was just changed and I don't see any indication of oil leaking anywhere. Could it be the sensor?
First off I wouldnt drive your car until you make sure that you have indeed oil pressure and that the gauge is a false reading, driving your car if in fact it has no oil pressure will severly damage your engine, but firstly i would check the oil pressure switch its located on the passenger side of the engine right back from the oil filter make sure the connector is clean and free from oil and corrosion if the connector appears to be in good shape take a paper clip and insert it between the 2 terminals inside the connector your oil pressure gauge should peak at 80 PSI that tells you that your gauge and all related wiring are good and in working condition, secondly remove the oil pressure switch and hook an manual oil pressure gauge up to you engine and start the engine the guage should have a oil pressure reading anywhere from 30 PSI to 55PSI depending on engine temperature if theres oil pressure on your manual gauge replace the oil pressure switch with a new unit, if you still have 0 PSI on your gauge then stop your engine immediatly and start looking at your oil pump and lubricating system for a problem.
Dec 06, 2010 | 2001 Jeep Grand Cherokee
1995 jeep cherokee sport 4.0L. Oil gauge keeps sending false message ie. jumps from almost center past the highest point on the gauge. How do I fix this problem? where is the gauge sender located?
OIL PRESSURE SWITCH-I'm not sure if this is the gauge sender, though. 1995 Jeep Grand Cherokee 4WD 4.0L MFI 6cyl The Oil Pressure Switch is located: Under hood, passenger side, lower engine area, above oil pan, mounted in engine block.
Nov 01, 2010 | 1995 Jeep Cherokee
What does check gauge on a 2002 jeep grand cherokee mean?
it means you have a out of safe range measuring on 1 of your gages usually temperatre is high or low oil pressure or not charging
Jul 18, 2010 | 2001 Jeep Grand Cherokee
My 2001 Jeep Grand Cherokee Loredo, straight six, is having a problem that the oil pressure gauge goes to 0 and my check gauges light comes on but when i accelerate it goes back up and the light goes off. ...
Your problem could be the result of a bad pressure sending unit but I would take care of that immediately. If the pressure doesn't return to normal after installing the new unit, do not drive 'til you have a mechanical gauge installed and the actual pressure checked and the problem corrected.
Apr 19, 2010 | 2001 Jeep Cherokee
Oil pressure gauge shows 60-80
the oil sending unit that screws in the block beside the oil filter may be faulty,
the worst thing would be the oil pump its self the regulator valve on it
Jan 26, 2010 | 2000 Jeep Grand Cherokee
Oil Pressure Always Runs High - 2002 Grand Jeep Cherokee
If your oil pressure is running in the red this would indicate too much oil in the system. You should have your oil changed and refilled soon or you run the risk of burning out the oil pump. At idle your pressure should be just over a quarter of what your gauge has. At highway speed it should not exceed 3/4 of the gauge unless your going in excess of 100 MPH. Change the oil and filter and your vehicle should be fine.
Jul 27, 2009 | 2001 Jeep Grand Cherokee
1993 Jeep Grand Cherokee, V6. Oil Pressure Gauge Read High.
it could be the sensor you should look at the oil pressure relief valve
Jun 10, 2009 | 1994 Jeep Cherokee
Jeep 2001 Grand Cherokee Limited Logo
69 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Duff Howell
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
